[mapguide-users] Creating Packages dynamically
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Wed Jan 21 02:57:00 EST 2009
0) Seriously, scroll down to the initial response in the mail for a link
to the code.
1) You recently posted about the LayerDefinitionFactory, so
surely you know how to load xml.
Regards, Kenneth Skovhede, GEOGRAF A/S
padmini godavarthi skrev:
> Hi Kenneth,
> Thanks for u r reply.
> u told for seeing available code.
> but where is that code i didn't get it.
> 1)how to load xml manually
> can u give me an idea so that it will be helpful to me.
> Thanks and Regards,
> Padmini
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> Restoring a package is quite a big and cumbersome task.
>> If you want to load a layer with oracle data, it is much easier to do so,
>> simply by loading the Xml manually. This can also be done without
>> Administrator credentials.
>> I can offer you no more advice than to look at the avalible code.
>> AFAIK, there is no example code avalible that does exactly what you
>> want, but the code I pointed you to should make it easier to do so.
>>> Hi Kenneth,
>>> u said that "Creating packages is an administrative task, so I won't
>>> expect
>>> many API
>>> users to have a need for it".but i want to load layers from oracle
>>> dynamically
>>> (i mean to say if i have a,b,c tables in oracle.i ant to load a,b or b,c
>>> or
>>> a,c layers based on requirement programmetically.so i thought dynamic
>>> maestro will support this requirement.)
>>> can u plz tell me
>>> 1) How can i achieve this requirement dynamically.
>>> Thanks and Regards,
>>> Padmini.
>>> Rodolfo Moreno wrote:
>>>> thanks Kenneth, It's cool.
>>>>> Yes, you need at least 1.0.9, but the released version has a bug,
>>>>> with creating packages, so you should get the preview release from the
>>>>> download page:
>>>>> http://trac.osgeo.org/mapguide/wiki/maestro/Downloads
>>>>> The package options are found in the "Package" menu.
>>>>> Rodolfo Moreno skrev:
>>>>>> Hi, I didn't know that Mapguide Maestro can create mapguide packages.
>>>>>> I have 1.0.8.27399 version and I have not found this option.
>>>>>> could you tell me how can I achieve this?
>>>>>> or maybe I need the last maestro version.
>>>>>> Thanks,
>>>>>>> Hello Padmini.
>>>>>>> There are no ready-to-use code in MaestroAPI for authoring (creating)
>>>>>>> MapGuide Packages.
>>>>>>> Creating packages is an administrative task, so I won't expect many
>>>>>>> API
>>>>>>> users to have a need for it.
>>>>>>> The Maestro application has code that creates and edits packages.
>>>>>>> The code can be found here:
>>>>>>> http://trac.osgeo.org/mapguide/browser/trunk/Tools/Maestro/Maestro/PackageManager
>>>>>>> Especially the file "PackageBuilder.cs" should be of interrest.
>>>>>>>> Hi,
>>>>>>>> iam using mapguide opensource 2.0 (with .net 2.0+IIS 5.1)
>>>>>>>> Presently iam using mapguide maestro for creating mapguide
>>>>>>>> packages.but
>>>>>>>> i
>>>>>>>> want to create my package dynamically through coding(using
>>>>>>>> maestroAPI.dll)
>>>>>>>> can any boby plz help me so that it will be very helpful to me.
>>>>>>>> Regards,
>>>>>>>> Padmini.
>>>>>>> _______________________________________________
>>>>>>> mapguide-users mailing list
>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>>> Rodolfo Moreno
>>>>>> CivilEng
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090121/f1d14499/attachment.html
