[mapguide-users] Creating Packages dynamically
padmini godavarthi godavarthi.padmini at gmail.com
Wed Jan 28 09:47:21 EST 2009
Hi Kenneth,
thanks for u r help.
Actually i want a help
u told that
"Restoring a package is quite a big and cumbersome task.
If you want to load a layer with oracle data, it is much easier to do so,
simply by loading the Xml manually. This can also be done without
Administrator credentials.
I can offer you no more advice than to look at the avalible code.
AFAIK, there is no example code avalible that does exactly what you
want, but the code I pointed you to should make it easier to do so."
can u plz tell me the step by step procedure exactly for creating feature
rsource,layers
so that it will be helpful to me for loading oracle data (approximately 10
layers)
plz consider this request.
Thanks and Regards,
Padmini
Kenneth Skovhede, GEOGRAF A/S wrote:
> 0) Seriously, scroll down to the initial response in the mail for a link
> to the code.
> 1) You recently posted about the LayerDefinitionFactory, so
> surely you know how to load xml.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> padmini godavarthi skrev:
>> Hi Kenneth,
>> Thanks for u r reply.
>> u told for seeing available code.
>> but where is that code i didn't get it.
>> 1)how to load xml manually
>> can u give me an idea so that it will be helpful to me.
>> Thanks and Regards,
>> Padmini
>>> so,
>>>> Hi Kenneth,
>>>> u said that "Creating packages is an administrative task, so I won't
>>>> expect
>>>> many API
>>>>  users to have a need for it".but i want to load layers from oracle
>>>> dynamically
>>>> (i mean to say if i have a,b,c tables in oracle.i ant to load a,b or
>>>> b,c
>>>> or
>>>> a,c layers based on requirement programmetically.so i thought dynamic
>>>> maestro will support this requirement.)
>>>> can u plz tell me
>>>> 1) How can i achieve this requirement dynamically.
>>>> Thanks and Regards,
>>>> Padmini.
>>>> Rodolfo Moreno wrote:
>>>>> thanks Kenneth, It's cool.
>>>>>> Yes, you need at least 1.0.9, but the released version has a bug,
>>>>>> with creating packages, so you should get the preview release from
>>>>>> the
>>>>>> download page:
>>>>>> http://trac.osgeo.org/mapguide/wiki/maestro/Downloads
>>>>>> The package options are found in the "Package" menu.
>>>>>> Rodolfo Moreno skrev:
>>>>>>> Hi, I didn't know that Mapguide Maestro can create mapguide
>>>>>>> packages.
>>>>>>> I have 1.0.8.27399 version and I have not found this option.
>>>>>>> could you tell me how can I achieve this?
>>>>>>> or maybe I need the last maestro version.
>>>>>>> Thanks,
>>>>>>>> Hello Padmini.
>>>>>>>> There are no ready-to-use code in MaestroAPI for authoring
>>>>>>>> (creating)
>>>>>>>> MapGuide Packages.
>>>>>>>> Creating packages is an administrative task, so I won't expect many
>>>>>>>> API
>>>>>>>> users to have a need for it.
>>>>>>>> The Maestro application has code that creates and edits packages.
>>>>>>>> The code can be found here:
>>>>>>>> http://trac.osgeo.org/mapguide/browser/trunk/Tools/Maestro/Maestro/PackageManager
>>>>>>>> Especially the file "PackageBuilder.cs" should be of interrest.
>>>>>>>>> Hi,
>>>>>>>>> iam using mapguide opensource 2.0 (with .net 2.0+IIS 5.1)
>>>>>>>>> Presently iam using mapguide maestro for creating  mapguide
>>>>>>>>> packages.but
>>>>>>>>> i
>>>>>>>>> want to create my package dynamically through coding(using
>>>>>>>>> maestroAPI.dll)
>>>>>>>>> can any boby plz help me so that it will be very helpful to me.
>>>>>>>>> Regards,
>>>>>>>>> Padmini.
>>>>>>>> _______________________________________________
>>>>>>>> mapguide-users mailing list
>>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>>>> Rodolfo Moreno
>>>>>>> CivilEng
View this message in context: http://n2.nabble.com/Creating-Packages-dynamically-tp2167497p2232608.html
