[mapguide-users] Adding a temporary Layer in MapGuide
Carmelo Saffioti
csaffi at libero.it
Tue Jan 20 09:50:03 EST 2009
Thank you for your help!
I'm seeing that the code you posted is very similar to the buffer code,
however I'm really new to MapGuide, so I hope you can help me understanding
how to make it work.
I created a Layout, using MapGuide Studio, on which I added a new custom
command for the Task panel, named "Route tracing". Therefore I created the
route_tracing.jsp file, on which I'm trying to use your code (translating it
from PHP to JSP) or the buffer.jsp code (which is already in JSP).
On both your code and buffer.jsp there is this code:
mapName = GetParameter(request, "MAPNAME");
sessionId = GetParameter(request, "SESSION");
- The question is: how can I pass the MAPNAME and SESSION values to the web
page?
The final result should be a web page, which opens when its Action Task item
is clicked, on which I can select and digit some options. After clicking a
button the page should get these values, and display the map with the
calculated additional layer on it.
I hope you can help me about that
Cheers
Carmelo
----- Original Message -----
From: "Arnaud De Groof" <Arnaud.DeGroof at spacebel.be>
To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
Sent: Monday, January 12, 2009 4:18 PM
Subject: RE: [mapguide-users] Adding a temporary Layer in MapGuide
The first code :
<?php
// Vital includes.
include "../../mapviewerphp/constants.php";
include "../../mapviewerphp/common.php";
$args = ($_SERVER['REQUEST_METHOD'] == "POST") ? $_POST : $_GET;
$sessionId = $args['SESSION'];
$mapName = $args['MAPNAME'];
$layerName1 = 'YYY';
$rlLayerResourceId = "Library://XXX/$layerName1.LayerDefinition";
InitializeWebTier();
$userInfo = new MgUserInformation($sessionId);
$siteConnection = new MgSiteConnection();
$siteConnection->Open($userInfo);
$resourceService =
$siteConnection->CreateService(MgServiceType::ResourceService);
// Read the MapDefinition into an XML DOM document object.
$md = " Library://XXX/$mapName.MapDefinition "; // TODO Constant!
$mdResourceId = new MgResourceIdentifier($md);
$mdReader = $resourceService->GetResourceContent($mdResourceId);
$mdXml = $mdReader->ToString();
$mdDomDoc = DOMDocument::loadXML($mdXml);
// Add a new MapLayer
$targetNode = $mdDomDoc->getElementsByTagName("MapLayer")->item(0);
$newNode = $targetNode->parentNode->insertBefore(new
DOMElement("MapLayer"), $targetNode);
$newNode->appendChild($mdDomDoc->createElement("Name", $layerName1));
$newNode->appendChild($mdDomDoc->createElement("ResourceId",
$rlLayerResourceId));
$newNode->appendChild($mdDomDoc->createElement("Selectable", "false"));
$newNode->appendChild($mdDomDoc->createElement("ShowInLegend",
"false"));
$newNode->appendChild($mdDomDoc->createElement("LegendLabel"));
$newNode->appendChild($mdDomDoc->createElement("ExpandInLegend",
"false"));
$newNode->appendChild($mdDomDoc->createElement("Visible", "true"));
$newNode->appendChild($mdDomDoc->createElement("Group"));
// Save the updated MapDefinition
$updatedXml = $mdDomDoc->saveXML();
$byteSource = new MgByteSource($updatedXml, strlen($updatedXml));
// Create the temporary MapDefinition
$sessionMapName = $mdResourceId->GetName();
$sessionMapDefinition =
"Session:$sessionId//$sessionMapName.MapDefinition";
$sessionResourceId = new MgResourceIdentifier($sessionMapDefinition);
// Write the updated MapDefinition
$resourceService->SetResource($sessionResourceId,
$byteSource->GetReader(), null);
//Test the updated MapDefinition
$md1 = "Session:$sessionId//X.MapDefinition";
$mdResourceId2 = new MgResourceIdentifier($md1);
$mdReader2 = $resourceService->GetResourceContent($mdResourceId2);
$mdXml2 = $mdReader2->ToString();
$mdDomDoc2 = DOMDocument::loadXML($mdXml2);
// Read the WebLayout into an XML DOM document object.
$wl = "Library://XXX/XXX.WebLayout"; // TODO Constant!
$wlResourceId = new MgResourceIdentifier($wl);
$wlReader = $resourceService->GetResourceContent($wlResourceId);
$wlXml = $wlReader->ToString();
$wlDomDoc = DOMDocument::loadXML($wlXml);
// Now, update the MapDefinition.
$mapdef = $wlDomDoc->getElementsByTagName("ResourceId")->item(0);
$mapdef->nodeValue = "$md1";
// Prepare the updated XML to be written out to the session.
$wlupdatedXml = $wlDomDoc->saveXML();
$wlbyteSource = new MgByteSource($wlupdatedXml, strlen($wlupdatedXml));
// Create a temporary WebLayout
$wlsessionMapName = $wlResourceId->GetName();
$wlsessionWebLayout = "Session:$sessionId//$wlsessionMapName.WebLayout";
$wlsessionResourceId = new MgResourceIdentifier($wlsessionWebLayout);
// Write the updated WebLayout to the session.
$resourceService->SetResource($wlsessionResourceId,
$wlbyteSource->GetReader(), null);
// Redirect to the Ajax viewer.
$redirectTo =
"mapguide/mapviewerajax/?SESSION=$sessionId&WEBLAYOUT=$wlsessionWebLayou
t";
$host = $_SERVER["HTTP_HOST"];
$url = "http://$host/$redirectTo";
//Test
$f = 'test.txt';
$handle = fopen($f,"w");
fwrite($handle, "test1:<".$mdXml.">\r\ntest 2 :<".$updatedXml.">\r\ntest
3 :<".$wlXml.">\r\ntest 4 :<".$wlupdatedXml.">\r\ntest 5 :<".$url.">");
fclose($handle);
// Redirect!
header("Location: $url");
exit;
___________________________________________________________________________________
E-MAIL DISCLAIMER
The present message may contain confidential and/or legally privileged
information.
If you are not the intended addressee and in case of a transmission error,
please notify the sender immediately and destroy this E-mail.
Disclosure, reproduction or distribution of this document and its possible
attachments is strictly forbidden.
SPACEBEL denies all liability for incomplete, improper, inaccurate,
intercepted,
(partly) destroyed, lost and/or belated transmission of the current
information
given that unencrypted electronic transmission cannot currently be
guaranteed
to be secure or error free. Upon request or in conformity with formal,
contractual
agreements, an originally signed hard copy will be sent to you to confirm
the information contained in this E-mail.
SPACEBEL denies all liability where E-mail is used for private use.
SPACEBEL cannot be held responsible for possible viruses that might corrupt
this
message and/or your computer system.
____________________________________________________________________________________
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
