[mapguide-users] Adding a temporary Layer in MapGuide
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Wed Jan 21 03:04:25 EST 2009
I have not used the AJAX viewer enough to know how to do this with tasks.
The values can be read from the viewer through some property functions:
http://mapguide.osgeo.org/files/mapguide/docs/2.0/viewerapi.html#mapframe_getsessionid
http://mapguide.osgeo.org/files/mapguide/docs/2.0/viewerapi.html#mapframe_getmapname
With those, you can manually pass them to the request, if you use the
"InvokeScript" method,
but there may be an easier way.
Regards, Kenneth Skovhede, GEOGRAF A/S
Carmelo Saffioti skrev:
> Thank you for your help!
> I'm seeing that the code you posted is very similar to the buffer
> code, however I'm really new to MapGuide, so I hope you can help me
> understanding how to make it work.
> I created a Layout, using MapGuide Studio, on which I added a new
> custom command for the Task panel, named "Route tracing". Therefore I
> created the route_tracing.jsp file, on which I'm trying to use your
> code (translating it from PHP to JSP) or the buffer.jsp code (which is
> already in JSP).
> On both your code and buffer.jsp there is this code:
> mapName = GetParameter(request, "MAPNAME");
> sessionId = GetParameter(request, "SESSION");
> - The question is: how can I pass the MAPNAME and SESSION values to
> the web page?
> The final result should be a web page, which opens when its Action
> Task item is clicked, on which I can select and digit some options.
> After clicking a button the page should get these values, and display
> the map with the calculated additional layer on it.
> I hope you can help me about that
> Cheers
> Carmelo
> ----- Original Message ----- From: "Arnaud De Groof"
> <Arnaud.DeGroof at spacebel.be>
> To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
> Sent: Monday, January 12, 2009 4:18 PM
> Subject: RE: [mapguide-users] Adding a temporary Layer in MapGuide
> The first code :
> <?php
> // Vital includes.
> include "../../mapviewerphp/constants.php";
> include "../../mapviewerphp/common.php";
> $args = ($_SERVER['REQUEST_METHOD'] == "POST") ? $_POST : $_GET;
> $sessionId = $args['SESSION'];
> $mapName = $args['MAPNAME'];
> $layerName1 = 'YYY';
> $rlLayerResourceId = "Library://XXX/$layerName1.LayerDefinition";
> InitializeWebTier();
> $userInfo = new MgUserInformation($sessionId);
> $siteConnection = new MgSiteConnection();
> $siteConnection->Open($userInfo);
> $resourceService =
> $siteConnection->CreateService(MgServiceType::ResourceService);
> // Read the MapDefinition into an XML DOM document object.
> $md = " Library://XXX/$mapName.MapDefinition "; // TODO Constant!
> $mdResourceId = new MgResourceIdentifier($md);
> $mdReader = $resourceService->GetResourceContent($mdResourceId);
> $mdXml = $mdReader->ToString();
> $mdDomDoc = DOMDocument::loadXML($mdXml);
> // Add a new MapLayer
> $targetNode = $mdDomDoc->getElementsByTagName("MapLayer")->item(0);
> $newNode = $targetNode->parentNode->insertBefore(new
> DOMElement("MapLayer"), $targetNode);
> $newNode->appendChild($mdDomDoc->createElement("Name", $layerName1));
> $newNode->appendChild($mdDomDoc->createElement("ResourceId",
> $rlLayerResourceId));
> $newNode->appendChild($mdDomDoc->createElement("Selectable", "false"));
> $newNode->appendChild($mdDomDoc->createElement("ShowInLegend",
> "false"));
> $newNode->appendChild($mdDomDoc->createElement("LegendLabel"));
> $newNode->appendChild($mdDomDoc->createElement("ExpandInLegend",
> "false"));
> $newNode->appendChild($mdDomDoc->createElement("Visible", "true"));
> $newNode->appendChild($mdDomDoc->createElement("Group"));
> // Save the updated MapDefinition
> $updatedXml = $mdDomDoc->saveXML();
> $byteSource = new MgByteSource($updatedXml, strlen($updatedXml));
> // Create the temporary MapDefinition
> $sessionMapName = $mdResourceId->GetName();
> $sessionMapDefinition =
> "Session:$sessionId//$sessionMapName.MapDefinition";
> $sessionResourceId = new MgResourceIdentifier($sessionMapDefinition);
> // Write the updated MapDefinition
> $resourceService->SetResource($sessionResourceId,
> $byteSource->GetReader(), null);
> //Test the updated MapDefinition
> $md1 = "Session:$sessionId//X.MapDefinition";
> $mdResourceId2 = new MgResourceIdentifier($md1);
> $mdReader2 = $resourceService->GetResourceContent($mdResourceId2);
> $mdXml2 = $mdReader2->ToString();
> $mdDomDoc2 = DOMDocument::loadXML($mdXml2);
> // Read the WebLayout into an XML DOM document object.
> $wl = "Library://XXX/XXX.WebLayout"; // TODO Constant!
> $wlResourceId = new MgResourceIdentifier($wl);
> $wlReader = $resourceService->GetResourceContent($wlResourceId);
> $wlXml = $wlReader->ToString();
> $wlDomDoc = DOMDocument::loadXML($wlXml);
> // Now, update the MapDefinition.
> $mapdef = $wlDomDoc->getElementsByTagName("ResourceId")->item(0);
> $mapdef->nodeValue = "$md1";
> // Prepare the updated XML to be written out to the session.
> $wlupdatedXml = $wlDomDoc->saveXML();
> $wlbyteSource = new MgByteSource($wlupdatedXml, strlen($wlupdatedXml));
> // Create a temporary WebLayout
> $wlsessionMapName = $wlResourceId->GetName();
> $wlsessionWebLayout = "Session:$sessionId//$wlsessionMapName.WebLayout";
> $wlsessionResourceId = new MgResourceIdentifier($wlsessionWebLayout);
> // Write the updated WebLayout to the session.
> $resourceService->SetResource($wlsessionResourceId,
> $wlbyteSource->GetReader(), null);
> // Redirect to the Ajax viewer.
> $redirectTo =
> "mapguide/mapviewerajax/?SESSION=$sessionId&WEBLAYOUT=$wlsessionWebLayou
> t";
> $host = $_SERVER["HTTP_HOST"];
> $url = "http://$host/$redirectTo";
> //Test
> $f = 'test.txt';
> $handle = fopen($f,"w");
> fwrite($handle, "test1:<".$mdXml.">\r\ntest 2 :<".$updatedXml.">\r\ntest
> 3 :<".$wlXml.">\r\ntest 4 :<".$wlupdatedXml.">\r\ntest 5 :<".$url.">");
> fclose($handle);
> // Redirect!
> header("Location: $url");
> exit;
> ___________________________________________________________________________________
> E-MAIL DISCLAIMER
> The present message may contain confidential and/or legally privileged
> information.
> If you are not the intended addressee and in case of a transmission
> error,
> please notify the sender immediately and destroy this E-mail.
> Disclosure, reproduction or distribution of this document and its
> possible
> attachments is strictly forbidden.
> SPACEBEL denies all liability for incomplete, improper, inaccurate,
> intercepted,
> (partly) destroyed, lost and/or belated transmission of the current
> information
> given that unencrypted electronic transmission cannot currently be
> guaranteed
> to be secure or error free. Upon request or in conformity with formal,
> contractual
> agreements, an originally signed hard copy will be sent to you to confirm
> the information contained in this E-mail.
> SPACEBEL denies all liability where E-mail is used for private use.
> SPACEBEL cannot be held responsible for possible viruses that might
> corrupt this
> message and/or your computer system.
> ____________________________________________________________________________________
> mapguide-users mailing list
