[mapguide-users] Adding a temporary Layer in MapGuide
    Carmelo Saffioti
    csaffi at libero.it
    Wed Jan 21 04:33:33 EST 2009
Thank you for your reply Kenneth.
Trying examples on DevGuideSamples I discovered how to work with the Task
Pane...
Now I need to draw dynamically on the map points of known x,y coordinates,
after clicking on the appropriate Task item. I hope this can be done with
the buffer script you suggested me. Isn't it?
Cheers
Carmelo
----- Original Message -----
From: "Kenneth Skovhede, GEOGRAF A/S" <ks at geograf.dk>
To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
Sent: Wednesday, January 21, 2009 9:04 AM
Subject: Re: [mapguide-users] Adding a temporary Layer in MapGuide
>I have not used the AJAX viewer enough to know how to do this with tasks.
> The values can be read from the viewer through some property functions:
> http://mapguide.osgeo.org/files/mapguide/docs/2.0/viewerapi.html#mapframe_getsessionid
> http://mapguide.osgeo.org/files/mapguide/docs/2.0/viewerapi.html#mapframe_getmapname
> With those, you can manually pass them to the request, if you use the
> "InvokeScript" method,
> but there may be an easier way.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Carmelo Saffioti skrev:
>> Thank you for your help!
>> I'm seeing that the code you posted is very similar to the buffer code,
>> however I'm really new to MapGuide, so I hope you can help me
>> understanding how to make it work.
>> I created a Layout, using MapGuide Studio, on which I added a new custom
>> command for the Task panel, named "Route tracing". Therefore I created
>> the route_tracing.jsp file, on which I'm trying to use your code
>> (translating it from PHP to JSP) or the buffer.jsp code (which is already
>> in JSP).
>> On both your code and buffer.jsp there is this code:
>> mapName = GetParameter(request, "MAPNAME");
>> sessionId = GetParameter(request, "SESSION");
>> - The question is: how can I pass the MAPNAME and SESSION values to the
>> web page?
>> The final result should be a web page, which opens when its Action Task
>> item is clicked, on which I can select and digit some options. After
>> clicking a button the page should get these values, and display the map
>> with the calculated additional layer on it.
>> I hope you can help me about that
>> Cheers
>> Carmelo
>> ----- Original Message ----- From: "Arnaud De Groof"
>> <Arnaud.DeGroof at spacebel.be>
>> Sent: Monday, January 12, 2009 4:18 PM
>> Subject: RE: [mapguide-users] Adding a temporary Layer in MapGuide
>> The first code :
>> <?php
>> // Vital includes.
>> include "../../mapviewerphp/constants.php";
>> include "../../mapviewerphp/common.php";
>> $args = ($_SERVER['REQUEST_METHOD'] == "POST") ? $_POST : $_GET;
>> $sessionId = $args['SESSION'];
>> $mapName = $args['MAPNAME'];
>> $layerName1 = 'YYY';
>> $rlLayerResourceId = "Library://XXX/$layerName1.LayerDefinition";
>> InitializeWebTier();
>> $userInfo = new MgUserInformation($sessionId);
>> $siteConnection = new MgSiteConnection();
>> $siteConnection->Open($userInfo);
>> $resourceService =
>> $siteConnection->CreateService(MgServiceType::ResourceService);
>> // Read the MapDefinition into an XML DOM document object.
>> $md = " Library://XXX/$mapName.MapDefinition "; // TODO Constant!
>> $mdResourceId = new MgResourceIdentifier($md);
>> $mdReader = $resourceService->GetResourceContent($mdResourceId);
>> $mdXml = $mdReader->ToString();
>> $mdDomDoc = DOMDocument::loadXML($mdXml);
>> // Add a new MapLayer
>> $targetNode = $mdDomDoc->getElementsByTagName("MapLayer")->item(0);
>> $newNode = $targetNode->parentNode->insertBefore(new
>> DOMElement("MapLayer"), $targetNode);
>> $newNode->appendChild($mdDomDoc->createElement("Name", $layerName1));
>> $newNode->appendChild($mdDomDoc->createElement("ResourceId",
>> $rlLayerResourceId));
>> $newNode->appendChild($mdDomDoc->createElement("Selectable", "false"));
>> $newNode->appendChild($mdDomDoc->createElement("ShowInLegend",
>> "false"));
>> $newNode->appendChild($mdDomDoc->createElement("LegendLabel"));
>> $newNode->appendChild($mdDomDoc->createElement("ExpandInLegend",
>> "false"));
>> $newNode->appendChild($mdDomDoc->createElement("Visible", "true"));
>> $newNode->appendChild($mdDomDoc->createElement("Group"));
>> // Save the updated MapDefinition
>> $updatedXml = $mdDomDoc->saveXML();
>> $byteSource = new MgByteSource($updatedXml, strlen($updatedXml));
>> // Create the temporary MapDefinition
>> $sessionMapName = $mdResourceId->GetName();
>> $sessionMapDefinition =
>> "Session:$sessionId//$sessionMapName.MapDefinition";
>> $sessionResourceId = new MgResourceIdentifier($sessionMapDefinition);
>> // Write the updated MapDefinition
>> $resourceService->SetResource($sessionResourceId,
>> $byteSource->GetReader(), null);
>> //Test the updated MapDefinition
>> $md1 = "Session:$sessionId//X.MapDefinition";
>> $mdResourceId2 = new MgResourceIdentifier($md1);
>> $mdReader2 = $resourceService->GetResourceContent($mdResourceId2);
>> $mdXml2 = $mdReader2->ToString();
>> $mdDomDoc2 = DOMDocument::loadXML($mdXml2);
>> // Read the WebLayout into an XML DOM document object.
>> $wl = "Library://XXX/XXX.WebLayout"; // TODO Constant!
>> $wlResourceId = new MgResourceIdentifier($wl);
>> $wlReader = $resourceService->GetResourceContent($wlResourceId);
>> $wlXml = $wlReader->ToString();
>> $wlDomDoc = DOMDocument::loadXML($wlXml);
>> // Now, update the MapDefinition.
>> $mapdef = $wlDomDoc->getElementsByTagName("ResourceId")->item(0);
>> $mapdef->nodeValue = "$md1";
>> // Prepare the updated XML to be written out to the session.
>> $wlupdatedXml = $wlDomDoc->saveXML();
>> $wlbyteSource = new MgByteSource($wlupdatedXml, strlen($wlupdatedXml));
>> // Create a temporary WebLayout
>> $wlsessionMapName = $wlResourceId->GetName();
>> $wlsessionWebLayout = "Session:$sessionId//$wlsessionMapName.WebLayout";
>> $wlsessionResourceId = new MgResourceIdentifier($wlsessionWebLayout);
>> // Write the updated WebLayout to the session.
>> $resourceService->SetResource($wlsessionResourceId,
>> $wlbyteSource->GetReader(), null);
>> // Redirect to the Ajax viewer.
>> $redirectTo =
>> "mapguide/mapviewerajax/?SESSION=$sessionId&WEBLAYOUT=$wlsessionWebLayou
>> t";
>> $host = $_SERVER["HTTP_HOST"];
>> $url = "http://$host/$redirectTo";
>> //Test
>> $f = 'test.txt';
>> $handle = fopen($f,"w");
>> fwrite($handle, "test1:<".$mdXml.">\r\ntest 2 :<".$updatedXml.">\r\ntest
>> 3 :<".$wlXml.">\r\ntest 4 :<".$wlupdatedXml.">\r\ntest 5 :<".$url.">");
>> fclose($handle);
>> // Redirect!
>> header("Location: $url");
>> exit;
>> ___________________________________________________________________________________
>> E-MAIL DISCLAIMER
>> The present message may contain confidential and/or legally privileged
>> information.
>> If you are not the intended addressee and in case of a transmission
>> error,
>> please notify the sender immediately and destroy this E-mail.
>> Disclosure, reproduction or distribution of this document and its
>> possible
>> attachments is strictly forbidden.
>> SPACEBEL denies all liability for incomplete, improper, inaccurate,
>> intercepted,
>> (partly) destroyed, lost and/or belated transmission of the current
>> information
>> given that unencrypted electronic transmission cannot currently be
>> guaranteed
>> to be secure or error free. Upon request or in conformity with formal,
>> contractual
>> agreements, an originally signed hard copy will be sent to you to confirm
>> the information contained in this E-mail.
>> SPACEBEL denies all liability where E-mail is used for private use.
>> SPACEBEL cannot be held responsible for possible viruses that might
>> corrupt this
>> message and/or your computer system.
>> ____________________________________________________________________________________
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
