[mapguide-users] Adding a temporary Layer in MapGuide
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Jan 21 05:24:19 EST 2009
Yes, just insert points instead of the buffer feature.
Regards, Kenneth Skovhede, GEOGRAF A/S
Carmelo Saffioti skrev:
> Thank you for your reply Kenneth.
> Trying examples on DevGuideSamples I discovered how to work with the
> Task Pane...
> Now I need to draw dynamically on the map points of known x,y
> coordinates, after clicking on the appropriate Task item. I hope this
> can be done with the buffer script you suggested me. Isn't it?
> Cheers
> Carmelo
> ----- Original Message ----- From: "Kenneth Skovhede, GEOGRAF A/S"
> <ks at geograf.dk>
> To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
> Sent: Wednesday, January 21, 2009 9:04 AM
> Subject: Re: [mapguide-users] Adding a temporary Layer in MapGuide
>> I have not used the AJAX viewer enough to know how to do this with
>> tasks.
>> The values can be read from the viewer through some property functions:
>> http://mapguide.osgeo.org/files/mapguide/docs/2.0/viewerapi.html#mapframe_getsessionid
>> http://mapguide.osgeo.org/files/mapguide/docs/2.0/viewerapi.html#mapframe_getmapname
>> With those, you can manually pass them to the request, if you use the
>> "InvokeScript" method,
>> but there may be an easier way.
>>> Thank you for your help!
>>> I'm seeing that the code you posted is very similar to the buffer
>>> code, however I'm really new to MapGuide, so I hope you can help me
>>> understanding how to make it work.
>>> I created a Layout, using MapGuide Studio, on which I added a new
>>> custom command for the Task panel, named "Route tracing". Therefore
>>> I created the route_tracing.jsp file, on which I'm trying to use
>>> your code (translating it from PHP to JSP) or the buffer.jsp code
>>> (which is already in JSP).
>>> On both your code and buffer.jsp there is this code:
>>> mapName = GetParameter(request, "MAPNAME");
>>> sessionId = GetParameter(request, "SESSION");
>>> - The question is: how can I pass the MAPNAME and SESSION values to
>>> the web page?
>>> The final result should be a web page, which opens when its Action
>>> Task item is clicked, on which I can select and digit some options.
>>> After clicking a button the page should get these values, and
>>> display the map with the calculated additional layer on it.
>>> I hope you can help me about that
>>> Cheers
>>> Carmelo
>>> ----- Original Message ----- From: "Arnaud De Groof"
>>> <Arnaud.DeGroof at spacebel.be>
>>> Sent: Monday, January 12, 2009 4:18 PM
>>> Subject: RE: [mapguide-users] Adding a temporary Layer in MapGuide
>>> The first code :
>>> <?php
>>> // Vital includes.
>>> include "../../mapviewerphp/constants.php";
>>> include "../../mapviewerphp/common.php";
>>> $args = ($_SERVER['REQUEST_METHOD'] == "POST") ? $_POST : $_GET;
>>> $sessionId = $args['SESSION'];
>>> $mapName = $args['MAPNAME'];
>>> $layerName1 = 'YYY';
>>> $rlLayerResourceId = "Library://XXX/$layerName1.LayerDefinition";
>>> InitializeWebTier();
>>> $userInfo = new MgUserInformation($sessionId);
>>> $siteConnection = new MgSiteConnection();
>>> $siteConnection->Open($userInfo);
>>> $resourceService =
>>> $siteConnection->CreateService(MgServiceType::ResourceService);
>>> // Read the MapDefinition into an XML DOM document object.
>>> $md = " Library://XXX/$mapName.MapDefinition "; // TODO Constant!
>>> $mdResourceId = new MgResourceIdentifier($md);
>>> $mdReader = $resourceService->GetResourceContent($mdResourceId);
>>> $mdXml = $mdReader->ToString();
>>> $mdDomDoc = DOMDocument::loadXML($mdXml);
>>> // Add a new MapLayer
>>> $targetNode = $mdDomDoc->getElementsByTagName("MapLayer")->item(0);
>>> $newNode = $targetNode->parentNode->insertBefore(new
>>> DOMElement("MapLayer"), $targetNode);
>>> $newNode->appendChild($mdDomDoc->createElement("Name", $layerName1));
>>> $newNode->appendChild($mdDomDoc->createElement("ResourceId",
>>> $rlLayerResourceId));
>>> $newNode->appendChild($mdDomDoc->createElement("Selectable", "false"));
>>> $newNode->appendChild($mdDomDoc->createElement("ShowInLegend",
>>> "false"));
>>> $newNode->appendChild($mdDomDoc->createElement("LegendLabel"));
>>> $newNode->appendChild($mdDomDoc->createElement("ExpandInLegend",
>>> "false"));
>>> $newNode->appendChild($mdDomDoc->createElement("Visible", "true"));
>>> $newNode->appendChild($mdDomDoc->createElement("Group"));
>>> // Save the updated MapDefinition
>>> $updatedXml = $mdDomDoc->saveXML();
>>> $byteSource = new MgByteSource($updatedXml, strlen($updatedXml));
>>> // Create the temporary MapDefinition
>>> $sessionMapName = $mdResourceId->GetName();
>>> $sessionMapDefinition =
>>> "Session:$sessionId//$sessionMapName.MapDefinition";
>>> $sessionResourceId = new MgResourceIdentifier($sessionMapDefinition);
>>> // Write the updated MapDefinition
>>> $resourceService->SetResource($sessionResourceId,
>>> $byteSource->GetReader(), null);
>>> //Test the updated MapDefinition
>>> $md1 = "Session:$sessionId//X.MapDefinition";
>>> $mdResourceId2 = new MgResourceIdentifier($md1);
>>> $mdReader2 = $resourceService->GetResourceContent($mdResourceId2);
>>> $mdXml2 = $mdReader2->ToString();
>>> $mdDomDoc2 = DOMDocument::loadXML($mdXml2);
>>> // Read the WebLayout into an XML DOM document object.
>>> $wl = "Library://XXX/XXX.WebLayout"; // TODO Constant!
>>> $wlResourceId = new MgResourceIdentifier($wl);
>>> $wlReader = $resourceService->GetResourceContent($wlResourceId);
>>> $wlXml = $wlReader->ToString();
>>> $wlDomDoc = DOMDocument::loadXML($wlXml);
>>> // Now, update the MapDefinition.
>>> $mapdef = $wlDomDoc->getElementsByTagName("ResourceId")->item(0);
>>> $mapdef->nodeValue = "$md1";
>>> // Prepare the updated XML to be written out to the session.
>>> $wlupdatedXml = $wlDomDoc->saveXML();
>>> $wlbyteSource = new MgByteSource($wlupdatedXml, strlen($wlupdatedXml));
>>> // Create a temporary WebLayout
>>> $wlsessionMapName = $wlResourceId->GetName();
>>> $wlsessionWebLayout =
>>> "Session:$sessionId//$wlsessionMapName.WebLayout";
>>> $wlsessionResourceId = new MgResourceIdentifier($wlsessionWebLayout);
>>> // Write the updated WebLayout to the session.
>>> $resourceService->SetResource($wlsessionResourceId,
>>> $wlbyteSource->GetReader(), null);
>>> // Redirect to the Ajax viewer.
>>> $redirectTo =
>>> "mapguide/mapviewerajax/?SESSION=$sessionId&WEBLAYOUT=$wlsessionWebLayou
>>> t";
>>> $host = $_SERVER["HTTP_HOST"];
>>> $url = "http://$host/$redirectTo";
>>> //Test
>>> $f = 'test.txt';
>>> $handle = fopen($f,"w");
>>> fwrite($handle, "test1:<".$mdXml.">\r\ntest 2
>>> :<".$updatedXml.">\r\ntest
>>> 3 :<".$wlXml.">\r\ntest 4 :<".$wlupdatedXml.">\r\ntest 5 :<".$url.">");
>>> fclose($handle);
>>> // Redirect!
>>> header("Location: $url");
>>> exit;
>>> ___________________________________________________________________________________
>>> E-MAIL DISCLAIMER
>>> The present message may contain confidential and/or legally
>>> privileged information.
>>> If you are not the intended addressee and in case of a transmission
>>> error,
>>> please notify the sender immediately and destroy this E-mail.
>>> Disclosure, reproduction or distribution of this document and its
>>> possible
>>> attachments is strictly forbidden.
>>> SPACEBEL denies all liability for incomplete, improper, inaccurate,
>>> intercepted,
>>> (partly) destroyed, lost and/or belated transmission of the current
>>> information
>>> given that unencrypted electronic transmission cannot currently be
>>> guaranteed
>>> to be secure or error free. Upon request or in conformity with
>>> formal, contractual
>>> agreements, an originally signed hard copy will be sent to you to
>>> confirm
>>> the information contained in this E-mail.
>>> SPACEBEL denies all liability where E-mail is used for private use.
>>> SPACEBEL cannot be held responsible for possible viruses that might
>>> corrupt this
>>> message and/or your computer system.
>>> ____________________________________________________________________________________
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
