[mapguide-users] Mapguide raster problem
marius.360
marius at osssa.co.za
Wed Jan 21 07:50:56 EST 2009
That is good news, at least I know someone is looking at this! If they find a
solution, will it be included in later MGOS releases?
Marius
zspitzer wrote:
> or buy a license for MGE and use the autodesk raster provider ...
> I managed to demonstrate the problem to the autodesk team with a good test
> case
> and they are going to look into the problem...
> z
> On Tue, Jan 20, 2009 at 6:35 PM, Maciej Skorczewski
> <maciej.skorczewski at procad.pl> wrote:
>> Hi!
>> My advice is:
>> 1. Add Raster layer whit scale (ex. when user goto or zoom to scale 2000
>> the
>> you display layer, you can set this in: Scale range - MG Studio,raster
>> layer
>> style).
>> 2. add scrit to your serwer who will reset mgserwice cyclically, this can
>> help when mgserwer display raster (mgserwice have big problem with
>> stability), mgservice can get to 300MB of ram, and that slow down all, or
>> it
>> stop working.
>> 3. You can try to add Base Layers, but in may opinion this is no good
>> solution,because when Mgserver thry to generate image tile image
>> mgservice
>> can hand down... (try to set this and take a look on CPU and RAM)
>> 4. Try to reduce your raster files.
>> In may project was about 10GB of Raster files, i cut size to 3GB, after
>> add
>> Scale range all works fine , my rating is 8/10
>> macieksk
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com
> +61 405 847 168
View this message in context: http://n2.nabble.com/Mapguide-raster-problem-tp2180266p2191990.html
