[mapguide-users] Two maps in the same layout
Rodolfo Moreno
rmoreno at voxiva.com
Wed Jan 21 10:46:58 EST 2009
Hi Jackie,
I don't understand what you want to tell me, could you elaborate on your
idea?
this the code of my beginning page
<script runat="server">
String webLayout =
"Library://Samples/Sheboygan/Layouts/SheboyganAspTest.WebLayout";
String defaultUser = "Anonymous";
String defaultPassword = "";
String sessionId1 = "";
String sessionId2 = "";
</script>
try
// Initialize a session and register a variable to hold the
// session id, then initialize the Web Extensions, connect
// to the site, and create a session.
InitializeWebTier();
MgUserInformation userInfo = new MgUserInformation(defaultUser,
defaultPassword);
MgSite site = new MgSite();
site.Open(userInfo);
sessionId1 = site.CreateSession();
sessionId2 = site.CreateSession();
catch (Exception e)
Response.Write(e.Message);
<html>
<head>
<title>Viewer Sample Application</title>
</head>
<frameset rows="30,*" frameborder="no" framespacing="0">
<frame id="titleFrame" frameborder="no" marginwidth="0" marginheight="0"
scrolling="no" src="title.html">
<frameset cols="50%,50%">
<frame id="viewer1Frame" frameborder="no" marginwidth="0"
marginheight="0" scrolling="no"
src="/mapguide/mapviewernet/ajaxviewer.aspx?SESSION=<%=sessionId1%>&WEBLAYOUT=<%=webLayout%>&THEMINGTYPE=1">
<frame id="viewer2Frame" frameborder="no" marginwidth="0"
src="/mapguide/mapviewernet/ajaxviewer.aspx?SESSION=<%=sessionId2%>&WEBLAYOUT=<%=webLayout%>&THEMINGTYPE=2">
</frameset>
</frameset>
</html>
thanks,
Jackie Ng wrote:
> The easiest way is to have an outer frameset (or 2 outer iframes) that
> points to your individual ajax viewers.
> - Jackie
> Rodolfo Moreno wrote:
>> I want to put two maps in the same layout and moreover each map must be
>> themed in different way just after of that the application to be loaded
>> (the theming must be done automatically according to a placed preference
>> in the first time that the application to be loaded).
>> I did a test application usign ajax viewer and I got it, however I have
>> modified many files of the mapguide extensions (MAINFRAME.ASPX,
>> FRAMESETTASKBAR.TEMPL, FRAMESETNOTASKBAR.TEMPL, MAPFRAME.ASPX,
>> AJAXMAPPANE.TEMPL).
>> I would like to know if it's possible to achieve it without the need of
>> modifying that files?
>> Also I'd like to know if it's possible to do it in FUSION viewer (I
>> prefer FUSION than AJAXVIEWER).
>> I am attaching a image of my test application.
>> thanks in advance,
>> http://n2.nabble.com/file/n2189508/testApp.jpg
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/Two-maps-in-the-same-layout-tp2189508p2192823.html
