[mapguide-users] Two maps in the same layout
Jackie Ng jumpinjackie at gmail.com
Tue Jan 20 18:23:28 EST 2009
The easiest way is to have an outer frameset (or 2 outer iframes) that points
to your individual ajax viewers.
- Jackie
Rodolfo Moreno wrote:
> I want to put two maps in the same layout and moreover each map must be
> themed in different way just after of that the application to be loaded
> (the theming must be done automatically according to a placed preference
> in the first time that the application to be loaded).
> I did a test application usign ajax viewer and I got it, however I have
> modified many files of the mapguide extensions (MAINFRAME.ASPX,
> FRAMESETTASKBAR.TEMPL, FRAMESETNOTASKBAR.TEMPL, MAPFRAME.ASPX,
> AJAXMAPPANE.TEMPL).
> I would like to know if it's possible to achieve it without the need of
> modifying that files?
> Also I'd like to know if it's possible to do it in FUSION viewer (I prefer
> FUSION than AJAXVIEWER).
> I am attaching a image of my test application.
> thanks in advance,
>  http://n2.nabble.com/file/n2189508/testApp.jpg
View this message in context: http://n2.nabble.com/Two-maps-in-the-same-layout-tp2189508p2189542.html
