[mapguide-users] SetSelectionXML 'Stack overflow at line 0' errow
Matteo matteo.conte1979 at libero.it
Thu Jan 22 14:27:32 EST 2009
Hi all,
  I work with MGOS 2.0.2 on windows XP. I develop with ASP.NET. When I try
to select some feature with a code filter the SetSelectionXML function get
me  the follow error "Stack overflow at line 0". The value of parameter that
I send to the function is:
<?xml version="1.0" encoding="UTF-8"?><FeatureSet
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd"> <Layer
id="4b540ce0-0000-1000-8000-000475cae734">  <Class id="Default:Zona1_a7">
<ID>APmZuQjg2UI=</ID>  </Class> </Layer></FeatureSet>
What is wrong?
Thanks
Matteo
View this message in context: http://n2.nabble.com/SetSelectionXML-%27Stack-overflow-at-line-0%27-errow-tp2199620p2199620.html
