[mapguide-users] SetSelectionXML 'Stack overflow at line 0' errow
Chris Claydon chris.claydon at autodesk.com
Thu Jan 22 14:35:23 EST 2009
I don't see any errors in the format of the XML. Are you retrieving the layer ID dynamically?
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Matteo
Sent: Thursday, January 22, 2009 12:28 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] SetSelectionXML 'Stack overflow at line 0' errow
Hi all,
  I work with MGOS 2.0.2 on windows XP. I develop with ASP.NET. When I try
to select some feature with a code filter the SetSelectionXML function get
me  the follow error "Stack overflow at line 0". The value of parameter that
I send to the function is:
<?xml version="1.0" encoding="UTF-8"?><FeatureSet
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd"> <Layer
id="4b540ce0-0000-1000-8000-000475cae734">  <Class id="Default:Zona1_a7">
<ID>APmZuQjg2UI=</ID>  </Class> </Layer></FeatureSet>
What is wrong?
Thanks
Matteo
View this message in context: http://n2.nabble.com/SetSelectionXML-%27Stack-overflow-at-line-0%27-errow-tp2199620p2199620.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
