[mapguide-users] SetSelectionXML 'Stack overflow at line 0' errow
Matteo matteo.conte1979 at libero.it
Thu Jan 22 15:01:26 EST 2009
Hi Chris,
  I use this code:
                    objMap = New MgMap(objMGSite)
                    objMap.Open(objMapId.GetName)
                    objLayer = objMap.GetLayers.GetItem(strLayer)
                    objQueryIdOptions = New MgFeatureQueryOptions()
                    objQueryIdOptions.SetFilter(strFilter)
                    Dim objFeatureR2 As MgFeatureReader =
objLayer.SelectFeatures(objQueryIdOptions)
                    Response.Write("<br/>ObjFeature")
                    objSelection = New MgSelection(objMap)
                    objSelection.AddFeatures(objLayer, objFeatureR2, 0)
                    Dim strXML as String=objSelection.ToXML()
At the end of ASP.NET function I put the strXML value into as html input box
then I call the Javascript code
..mapFrame.SetSelectionXML(document.XMLinput.value)
Thanks
Matteo
Chris Claydon wrote:
> I don't see any errors in the format of the XML. Are you retrieving the
> layer ID dynamically?
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Matteo
> Sent: Thursday, January 22, 2009 12:28 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] SetSelectionXML 'Stack overflow at line 0' errow
> Hi all,
>   I work with MGOS 2.0.2 on windows XP. I develop with ASP.NET. When I try
> to select some feature with a code filter the SetSelectionXML function get
> me  the follow error "Stack overflow at line 0". The value of parameter
> that
> I send to the function is:
> <?xml version="1.0" encoding="UTF-8"?><FeatureSet
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd"> <Layer
> id="4b540ce0-0000-1000-8000-000475cae734">  <Class id="Default:Zona1_a7">
> <ID>APmZuQjg2UI=</ID>  </Class> </Layer></FeatureSet>
> What is wrong?
> Thanks
> Matteo
> http://n2.nabble.com/SetSelectionXML-%27Stack-overflow-at-line-0%27-errow-tp2199620p2199620.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://n2.nabble.com/SetSelectionXML-%27Stack-overflow-at-line-0%27-errow-tp2199620p2199806.html
