[mapguide-users] Load Layer Definition XML
wordsy
mwordell at gmail.com
Thu Jan 22 14:41:30 EST 2009
Hey Everyone;
Fairly new to MGOS.
Here is what I am trying to do.
I have a map with many Layers. One of my requirements is to allow users to
be able to change the layer styles via a web wizard. The user will be able
to adjust certain styles for line/point/polygon (surface). Ie font, symbol,
line thickness, color etc.
Already my site allows a user to select the layer they want to change, then
change the styles for a point only. The changing doesn't seem to be a
problem right now.
The problem I have:
Once a user selects the layer they want to load. How would I get the layer
and use XML document or XPATH or something to allow the users edit XML
nodes.
Here is my code that checks to see what layer type I have when the user
selects the layer. I have 3 different user controls (one for line, one for
poly, one for line). What I really want, is to load the layer and populate
the appropriate controls inside the user control.
MgSiteConnection conn = InitializeGisWebTier();
string resource = "Library://MUNICIPALITIES/" + Municipality +
"/2_DATA/" + LayerName + ".FeatureSource";
MgResourceService svc =
(MgResourceService)conn.CreateService(MgServiceType.ResourceService );
// Populate some values that we will need.
MgResourceIdentifier resourceId = new
MgResourceIdentifier(resource);
MgFeatureReader featureReader =
LayerDefinitionFactory.MakeAFeatureReader(conn, resourceId);
// Find out what type of Geometric property the FeatureSource we
uploaded has.
string geometricPropertyType =
LayerDefinitionFactory.GetFeatureSourceGeometricPropertyType(featureReader);
switch (geometricPropertyType)
case "SURFACE":
// We load the Polygon usercontrol
this.phStylizeLayerControl.Controls.Add(new
PolygonStyleBuilder());
break;
case "POINT":
// we load the point usercontrol
//this.phStylizeLayerControl.Controls.Add(new
PointStyleBuilder());
PointStyleBuilder control =
(PointStyleBuilder)LoadControl("~/Pages/Controls/PointStyleBuilder.ascx");
this.phStylizeLayerControl.Controls.Add(control);
txtSymbol.Enabled = true;
txtSymbolSize.Enabled = true;
break;
case "CURVE":
// we load the line user control
LineStyleBuilder());
break;
Thanks for any help in advance.
View this message in context: http://n2.nabble.com/Load-Layer-Definition-XML-tp2199703p2199703.html
