[mapguide-users] Two maps in the same layout
Rodolfo Moreno rmoreno at voxiva.com
Thu Jan 22 15:42:06 EST 2009
Only for completing my idea about the dynamic theming in the first time:
<frame id="viewer1Frame" frameborder="no" marginwidth="0" marginheight="0"
scrolling="no"
src="/mapguide/mapviewernet/ajaxviewer.aspx?SESSION=<%=sessionId1%>&WEBLAYOUT=<%=webLayout%>&THEMINGTYPE=1">
In this sentence you can see a parameter added called THEMINGTYPE, which is
why I have modified the viewer files. I have not found another way of doing
theming dynamically in the first time.
I would like to do it without modifying the viewer files and much better if
it is possible to do in FUSION viewer.
Thanks in advance,
Rodolfo Moreno wrote:
> Hi Mark, about your question:
> - Why would you need to modify any of the viewer files in order to have 2
> pages in your map?
> I have modified viewer files because I want to set a themed layer
> dynamically in each map in the first time that my application to be
> loaded.
> My use case is: The theming is placed according to a preference to set by
> the user in previous session. Thus the applicacion could show two
> preferences on the same map(and the same layout). This is useful when you
> want to show comparisons, for example: To compare population 1980 vs 1990
> (like a dashboard).
> Ivan good sugestion about the iframes, it's better than frameset. However
> I would like to do it using FUSION viewer. Is it possible?
> Thanks,
> Ivan Milicevic wrote:
>> Hi,
>> Frameset sucks, use iframe, it's more flexibile.
>> In C# code create two mgSession's and define two differen  weblayout's.
>>         MgUserInformation userInfo = new MgUserInformation(defaultUser,
>> defaultPassword);
>>         MgSite site = new MgSite();
>>         site.Open(userInfo);
>>         sessionId = site.CreateSession();
>>         sessionId2 = site.CreateSession();
>>         webLayout = "Library://PROJEKTI/PRIKAZI/1.WebLayout";
>>          weblayout2 = "Library://PROJEKTI/PRIKAZI/1mm.WebLayout";
>> Here, after <body>..
>> <div><iframe id="viewerFrame" width="100%" height="100%" frameborder="0"
>> marginwidth="0" marginheight="0" scrolling="no"
>> src="../mapviewernet/ajaxviewer.aspx?SESSION=<%=sessionId%>&WEBLAYOUT=<%
>> =webLayout"%> ></iframe><div>
>> <div><iframe id="viewerFrame2" width="100%" height="100%"
>> frameborder="0" marginwidth="0" marginheight="0" scrolling="no"
>> src="../mapviewernet/ajaxviewer.aspx?SESSION=<%=sessionId2%>&WEBLAYOUT=<
>> %=webLayout2%>></iframe><div>
>> Put iframes into div's so you can place it absolutely, moving maps,
>> ect...
>> The point is that you must have two mgSessionId's and two weblayout's.
>> Hope this helps.
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mark
>> Pendergraft
>> Sent: Wednesday, January 21, 2009 5:15 PM
>> To: MapGuide Users Mail List
>> Subject: RE: [mapguide-users] Two maps in the same layout
>> Roldolfo,
>> Sorry I didn't look at your code.  It's pretty much exactly the same as
>> what I posted.  Why would you need to modify any of the viewer files in
>> order to have 2 pages in your map?
>> I was able to create a 2 map page using framesets in the same manner
>> that you did.
>> -Mark
>> Pendergraft
>> Sent: Wednesday, January 21, 2009 8:10 AM
>> Many people have their page in a frameset.  Here is an example which has
>> two frames, 1 for a title.html page and 1 for the mapguide viewer.  Here
>> is an example of what your frameset page might look like (in VB.NET)
>> <%@ Page Language="VB" Debug="true" %>
>> <%@ Import Namespace="OSGeo.MapGuide" %>
>> <!-- #Include File="UtilityFunctions.aspx" -->
>> <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
>> "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
>> <script runat="server">
>>     Private webLayout As String = "Library://MGA/Layout/MGA Web
>> Layout.WebLayout"
>>     Private defaultUser As String = "Anonymous"
>>     Private defaultPassword As String = ""
>>     Private SessionId As String = ""
>>     Private addRequests As String = ""
>>     Private Parameters As String = ""
>> </script>
>>     Try
>>         ' Initialize a session and register a variable to hold the
>>         ' session id, then initialize the Web Extensions, connect
>>         ' to the site, and create a session.
>>         InitializeWebTier()
>>         Dim userInfo As New MgUserInformation(defaultUser,
>> defaultPassword)
>>         Dim site As New MgSite()
>>         site.Open(userInfo)
>>         SessionId = site.CreateSession()
>>     Catch ex As Exception
>>         Response.Write(ex.Message)
>>     End Try
>> <frameset rows="50,*">
>>     <frame id="titleFrame" frameborder="0" marginwidth="0"
>>         src="http://localhost/mapguide/mga/title.html">
>>     <frame id="viewerFrame" frameborder="0" marginwidth="0"
>> src="http://localhost/mapguide/mapviewernet/ajaxviewer.aspx?SESSION=<%=s
>> essionId%>&WEBLAYOUT=<%=webLayout%>&LOCALE=en">
>> </frameset>
>> This page creates a horizontal split page with two pages in it.  If you
>> adjusted frameset rows="50,*" to "frameset cols="*,*" you would get a
>> page split in half vertically.  Then change the src="" element to the
>> two pages you want shown.
>> Hope that clears it up a bit.
>> -Mark Pendergraft
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rodolfo
>> Moreno
>> Sent: Wednesday, January 21, 2009 7:47 AM
>> To: mapguide-users at lists.osgeo.org
>> Subject: Re: [mapguide-users] Two maps in the same layout
>> Hi Jackie,
>> I don't understand what you want to tell me, could you elaborate on your
>> idea?
>> this the code of my beginning page
>> String webLayout =
>> "Library://Samples/Sheboygan/Layouts/SheboyganAspTest.WebLayout";
>> String defaultUser = "Anonymous";
>> String defaultPassword = "";
>> String sessionId1 = "";
>> String sessionId2 = "";
>> </script>
>>     try
>>         // Initialize a session and register a variable to hold the
>>         // session id, then initialize the Web Extensions, connect
>>         // to the site, and create a session.
>>         InitializeWebTier();
>> defaultPassword);
>>         sessionId1 = site.CreateSession();
>>     catch (Exception e)
>>         Response.Write(e.Message);
>> <html>
>> <head>
>>       <title>Viewer Sample Application</title>
>> </head>
>> <frameset rows="30,*" frameborder="no" framespacing="0">
>>  <frame id="titleFrame" frameborder="no" marginwidth="0"
>> marginheight="0"
>> scrolling="no" src="title.html">
>>   <frameset cols="50%,50%">
>>           <frame id="viewer2Frame" frameborder="no" marginwidth="0"
>> src="/mapguide/mapviewernet/ajaxviewer.aspx?SESSION=<%=sessionId2%>&WEBL
>> AYOUT=<%=webLayout%>&THEMINGTYPE=2">
>>   </frameset>
>> </frameset>
>> </html>
>> thanks,
>> Jackie Ng wrote:
>>> The easiest way is to have an outer frameset (or 2 outer iframes) that
>>> points to your individual ajax viewers.
>>> - Jackie
>>>> I want to put two maps in the same layout and moreover each map must
>> be
>>>> themed in different way just after of that the application to be
>> loaded
>>>> (the theming must be done automatically according to a placed
>> preference
>>>> in the first time that the application to be loaded).
>>>> I did a test application usign ajax viewer and I got it, however I
>> have
>>>> modified many files of the mapguide extensions (MAINFRAME.ASPX,
>>>> FRAMESETTASKBAR.TEMPL, FRAMESETNOTASKBAR.TEMPL, MAPFRAME.ASPX,
>>>> AJAXMAPPANE.TEMPL).
>>>> I would like to know if it's possible to achieve it without the need
>> of
>>>> modifying that files?
>>>> Also I'd like to know if it's possible to do it in FUSION viewer (I
>>>> prefer FUSION than AJAXVIEWER).
>>>> I am attaching a image of my test application.
>>>> thanks in advance,
>>>>  http://n2.nabble.com/file/n2189508/testApp.jpg
>> Rodolfo Moreno
>> CivilEng
>> View this message in context:
>> http://n2.nabble.com/Two-maps-in-the-same-layout-tp2189508p2192823.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/Two-maps-in-the-same-layout-tp2189508p2200043.html
