[mapguide-users] Second instance
Atika Irfan irfan.atika at gmail.com
Tue Jan 27 05:11:19 EST 2009
> If you have two different services running, you can exchange packages
> between them.
> Physical machine location is irrelevant, but most users have seperate
> machines.
> MapGuide is fairly demanding on memory and CPU power, so I would not
> recommend
> running more than one instance on each machine. Installation and
> configuration of the
> second service is also quite a pain.
>  thanks a lot for your help... but i dont get it ..you should not have 2
> appliaction on the same server which are using the same resources ?? ... i
> am not taking about installing another mapsever on the same machine ... i
> just want another application (or you can say layout) on the same server,
> having same resource set but different users (previous one was a private
> appliaction now i want a public one) ....
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090127/7059d683/attachment.html
