[mapguide-users] Second instance
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Tue Jan 27 09:20:22 EST 2009
Ok, so you have a solution set up, and want a copy of it.
Packages won't do that, because they restore items into the same spot, so
restoring a package would overwrite your data.
If you use Studio, you can copy layers etc. around, but it won't update
references.
If you use Maestro, you can copy, move and rename folders or items, and
it will update the references.
If you have all items for the solution in a single folder, you can
simply make a copy of it.
Studio will tell you something about broken references, and Maestro will
update all the items to
follow the new folder.
Regards, Kenneth Skovhede, GEOGRAF A/S
Atika Irfan skrev:
> If you have two different services running, you can exchange
> packages between them.
> Physical machine location is irrelevant, but most users have
> seperate machines.
> MapGuide is fairly demanding on memory and CPU power, so I would
> not recommend
> running more than one instance on each machine. Installation and
> configuration of the
> second service is also quite a pain.
>> thanks a lot for your help... but i dont get it ..you should not
>> have 2 appliaction on the same server which are using the same
>> resources ?? ... i am not taking about installing another
>> mapsever on the same machine ... i just want another application
>> (or you can say layout) on the same server, having same resource
>> set but different users (previous one was a private appliaction
>> now i want a public one) ....
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090127/d4b9fdc7/attachment.html
