[mapguide-users] (no subject)
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Jan 27 09:30:32 EST 2009
There is a user guide for Maestro here:
http://trac.osgeo.org/mapguide/wiki/maestro/UserGuide
MapGuide only uses SDF v.3, you will need some tool to convert an SDF v2
file to SDF v.3.
You can use MapGuide Studio from Autodesk to load SDF v2. files.
MapGuide Studio comes with a manual, and is fairly cheap.
There is also a trial version avalible.
Regards, Kenneth Skovhede, GEOGRAF A/S
syncro balon skrev:
> hellow,
> I m a new member and I m intersting by mapguide open source 2.x,
> i want knew how we can create a package by Mapguide maestro from A to
> Z (how we can load data, map, layout ....)
> i m trying to load a file SDF bat i have error with version 2 (how
> converted SDF version 2 to version 3, i m trying to use autodesk map
> 2008 bat when i import a file sdf version 2 i have as result one layer
> imported)
> think's for help
> Découvrez toutes les possibilités de communication avec vos proches
> <http://www.microsoft.com/windows/windowslive/default.aspx>
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090127/39a8ce27/attachment.html
