[mapguide-users] Open MapGuide minimized frame
Jackie Ng
jumpinjackie at gmail.com
Thu Jan 29 01:31:07 EST 2009
If you want to react to the viewer completing the loading of the map. You can
use the technique described here:
http://trac.osgeo.org/mapguide/wiki/CodeSamples/JavaScript/AJAXViewerEventHooking
- Jackie
SandraH wrote:
> Hello,
> I embedded MapGuide into my application. I located the viewer in a
> frameset. The user can minimize or maximize the frames in this frameset.
> If I load MapGuide in the maximized frame, everything works fine. But my
> target is to open my program, with the minimized Dxf-Viewer. This causes
> some problems, e.g. the initial zoom is incorrect or the task-pane is not
> shown.
> My idea is to open MapGuide maximized and minimize the frame automatically
> after the loading is complete. Now I'm looking for a return value, which
> gives me the status of the viewer. (load succed or something like that...)
> Can anybody help me with my problem?
> Thank you.
> Sandra
View this message in context: http://n2.nabble.com/Open-MapGuide-minimized-frame-tp2235207p2237392.html
