[mapguide-users] having a problem for mapGuide
Jackie Ng jumpinjackie at gmail.com
Thu Jan 29 03:00:58 EST 2009
If you only have wamp installed on the (false) belief is is required for
MapGuide development, then you can safely uninstall it.
Apache's web root (that is installed with MapGuide) is at:
<your mapguide install directory>\WebServerExtensions\www
(ie. D:\Program Files\MapGuideOpenSource\WebServerExtensions\www)
This corresponds to a url of http://localhost:8008/mapguide (assuming
default settings)
Drop your PHP project in this directory and it will be accessible.
eg. If your PHP project is in:
D:\Program Files\MapGuideOpenSource\WebServerExtensions\www\MyProject
It can be accessed via this URL:
http://localhost:8008/mapguide/MyProject/<my starting page>.php
- Jackie
sara_ghafary wrote:
> thank you
> do i must deleted Wamp?
> Map guide  Web Extensions  installed in D:\Program Files
> \MapGuideOpenSource
> so ,where do  My PHP project  attach?
> what do parameter Pass between  My PHP Project and Map guide  Web
> Extensions ? :confused:
> Jackie Ng wrote:
>> I assume you have just installed MapGuide onto a machine that has an
>> existing WAMP installation.
>> If you installed MapGuide Web Extensions with the Apache/PHP option, it
>> is actually installing its own instance of Apache and PHP, and not using
>> the one in your WAMP installation.
>> - Jackie
>> sara_ghafary wrote:
>>>  hi ,
>>> i have a problem for mapGuide! ,i install SoftWares  "MapGuide Server"
>>> and "MapGuide Web Server Extensions"  ,when instal in drive "D:\Program
>>> files\MapGuideOpenSource"
>>> my php project   exist in c:\wamp\www  ,
>>> i do not khnow  how pass parameter between 2 project!
>>> please Help me
>>> tanks
View this message in context: http://n2.nabble.com/having-a-problem-for-mapGuide-tp2212083p2237646.html
