[mapguide-users] Maintaining MapGuide Session during Restart
bruce_weston ross.vernal at 1spatial.com
Thu Jan 29 10:54:21 EST 2009
Bruce D,
Are you suggesting that this can be done? Does anyone have a script or a
method of copying the session repository into a library object? Is there
even a way of creating a copy of the session as XML?
thanks,
Bruce W
Bruce Dechant wrote:
> Bruce,
> What you are doing by trying to replace the session repository of a
> running server is problematic and could lead to server instability. You
> really shouldn't do this.
> The session repository is meant for temporary runtime data only and not
> for persistent data. If you want any of your session repository data to
> survive a restart you need to use the library repository instead.
> Thanks,
> Bruce
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of bruce_weston
> Sent: Wednesday, January 28, 2009 2:34 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Maintaining MapGuide Session during Restart
> I'm just wondering if anyone has managed to do this yet? This is my
> attempted
> MapGuide restart script to keep the contents of the session folder backed
> up, but it doesn't work:
> echo MapGuide Scheduler Task Starting
> taskkill /F /FI "SERVICES eq MapGuideServer2.0"
> net stop MapGuideServer2.0
> REM xcopy c:\Progra~1\MapGuideOpenSource2.0\Server\Repositories\Session\*
> c:\Progra~1\MapGuideOpenSource2.0\SessionBackup\ /E /Y
> net start MapGuideServer2.0
> REM xcopy c:\Progra~1\MapGuideOpenSource2.0\SessionBackup\*
> c:\Progra~1\MapGuideOpenSource2.0\Server\Repositories\Session\ /E /Y
> echo MapGuide Scheduler Task Completed
> pause
> Is there session data stored anywhere else? I really want to make the
> process seamless for my users.
> Bruce
> http://n2.nabble.com/Maintaining-MapGuide-Session-during-Restart-tp2231199p2231199.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://n2.nabble.com/Maintaining-MapGuide-Session-during-Restart-tp2231199p2239668.html
