[mapguide-users] invokeurl
GordonL
gordon.luckett at arrowgeomatics.com
Thu Jan 29 15:25:56 EST 2009
Hi Andrew,
ok I figured it out. It is the InvokeURL.js file.
This file is found in the following folder:
\www\fusion\widgets
Here is the issue:
At line 40 it shows:
Fusion.Widget.InvokeURL.prototype = {
sFeatures :
'menubar=no,location=no,resizable=yes,status=no,scrollbars=yes',
Which is fine. I changed resizable=yes and added scrollbars=yes...so far so
good...
But, at line 120, it reads:
window.open(url, this.sTarget, this.sWinFeatures);
Ok, so the issue is that there is NO sWinFeatures...
I changed it to read:
window.open(url, this.sTarget, this.sFeatures);
And voilà! I am in business...whew. I thought I was losing my touch.
gordon
Andrew DeMerchant wrote:
> It wasn't part of the widget - i've been away from Fusion for too long
> now, and really can't recall. I would imagine it was in the .js file for
> that widget...sorry I'm no more help than that!
> On 1/29/2009 11:44 AM, GordonL wrote:
>> Hi Andrew,
>> I am having trouble finding the entry in Nabble. Do you have an example?
>> I
>> am sure I did this a couple of years ago, but I can't find it. Can it be
>> part of the Widget XML in Studio too?
>> thanks
>> gordon
>>> I did...I also turned on the scrollbars - but I can't recall how at the
>>> moment....do a search on Nabble, and you should find the answer.
>>> Andrew
>>> GordonL wrote:
>>>> Did you figure this out with Flexible Web Layouts? This fix works
>>>> great
>>>> for
>>>> Simple Web Layouts but how do we turn on Scrolling/Toolbars in the
>>>> InvokeURL
>>>> for Fusion?
>>>> Is it part of the InvokeURL.js file in the /fusion/wigets/ folder?
>>>> thanks
>>>> gordon
>>>>> Is there a way to modify the InvokeURL command to have it open a
>>>>> window
>>>>> with scrollbars and toolbars? Right now, if you tell it to open in a
>>>>> new
>>>>> window, that window never has scrollbars or toolbars. I need to turn
>>>>> those on somehow. I've looked through the AJAX viewer php files, but
>>>>> can't find the spot that I'd change.
>>>>> Andrew
>>>>> *Andrew DeMerchant*
>>>>> *Computer Technologist*
>>>>> ph.1-877-2GEMTEC x.163
>>>>> fax 506-453-9470
>>>>> /GEMTEC Limited<http://www.gemtec.ca>
>>>>> /191 Doak Road
>>>>> Fredericton, NB, Canada
>>>>> E3C 2E6
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> *Andrew DeMerchant*
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> E3C 2E6
View this message in context: http://n2.nabble.com/invokeurl-tp1816596p2241087.html
