[mapguide-users] invokeurl
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Thu Jan 29 10:57:10 EST 2009
It wasn't part of the widget - i've been away from Fusion for too long
now, and really can't recall. I would imagine it was in the .js file for
that widget...sorry I'm no more help than that!
On 1/29/2009 11:44 AM, GordonL wrote:
> Hi Andrew,
> I am having trouble finding the entry in Nabble. Do you have an example? I
> am sure I did this a couple of years ago, but I can't find it. Can it be
> part of the Widget XML in Studio too?
> thanks
> gordon
> Andrew DeMerchant wrote:
>> I did...I also turned on the scrollbars - but I can't recall how at the
>> moment....do a search on Nabble, and you should find the answer.
>> Andrew
>> GordonL wrote:
>>> Did you figure this out with Flexible Web Layouts? This fix works great
>>> for
>>> Simple Web Layouts but how do we turn on Scrolling/Toolbars in the
>>> InvokeURL
>>> for Fusion?
>>> Is it part of the InvokeURL.js file in the /fusion/wigets/ folder?
>>> thanks
>>> gordon
>>>> Is there a way to modify the InvokeURL command to have it open a window
>>>> with scrollbars and toolbars? Right now, if you tell it to open in a new
>>>> window, that window never has scrollbars or toolbars. I need to turn
>>>> those on somehow. I've looked through the AJAX viewer php files, but
>>>> can't find the spot that I'd change.
>>>> Andrew
>>>> *Andrew DeMerchant*
>>>> *Computer Technologist*
>>>> ph.1-877-2GEMTEC x.163
>>>> fax 506-453-9470
>>>> /GEMTEC Limited<http://www.gemtec.ca>
>>>> /191 Doak Road
>>>> Fredericton, NB, Canada
>>>> E3C 2E6
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
*Andrew DeMerchant*
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
