[mapguide-users] invokeurl
GordonL
gordon.luckett at arrowgeomatics.com
Thu Jan 29 10:44:43 EST 2009
Hi Andrew,
I am having trouble finding the entry in Nabble. Do you have an example? I
am sure I did this a couple of years ago, but I can't find it. Can it be
part of the Widget XML in Studio too?
thanks
gordon
Andrew DeMerchant wrote:
> I did...I also turned on the scrollbars - but I can't recall how at the
> moment....do a search on Nabble, and you should find the answer.
> Andrew
> GordonL wrote:
>> Did you figure this out with Flexible Web Layouts? This fix works great
>> for
>> Simple Web Layouts but how do we turn on Scrolling/Toolbars in the
>> InvokeURL
>> for Fusion?
>> Is it part of the InvokeURL.js file in the /fusion/wigets/ folder?
>> thanks
>> gordon
>>> Is there a way to modify the InvokeURL command to have it open a window
>>> with scrollbars and toolbars? Right now, if you tell it to open in a new
>>> window, that window never has scrollbars or toolbars. I need to turn
>>> those on somehow. I've looked through the AJAX viewer php files, but
>>> can't find the spot that I'd change.
>>> Andrew
>>> *Andrew DeMerchant*
>>> *Computer Technologist*
>>> ph.1-877-2GEMTEC x.163
>>> fax 506-453-9470
>>> /GEMTEC Limited <http://www.gemtec.ca>
>>> /191 Doak Road
>>> Fredericton, NB, Canada
>>> E3C 2E6
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/invokeurl-tp1816596p2239608.html
