[mapguide-users] invokeurl
Andrew DeMerchant andrew.demerchant at gemtec.ca
Fri Jan 23 19:27:05 EST 2009
I did...I also turned on the scrollbars - but I can't recall how at the
moment....do a search on Nabble, and you should find the answer.
Andrew
GordonL wrote:
> Did you figure this out with Flexible Web Layouts?  This fix works great for
> Simple Web Layouts but how do we turn on Scrolling/Toolbars in the InvokeURL
> for Fusion?
> Is it part of the InvokeURL.js file in the /fusion/wigets/ folder?
> thanks
> gordon
> Andrew DeMerchant wrote:
>> Is there a way to modify the InvokeURL command to have it open a window
>> with scrollbars and toolbars? Right now, if you tell it to open in a new
>> window, that window never has scrollbars or toolbars. I need to turn
>> those on somehow. I've looked through the AJAX viewer php files, but
>> can't find the spot that I'd change.
>> Andrew
>> 	*Andrew DeMerchant*
>> *Computer Technologist*
>> ph.1-877-2GEMTEC x.163
>> fax 506-453-9470
>> /GEMTEC Limited <http://www.gemtec.ca>
>> /191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
