[mapguide-users] invokeurl
GordonL gordon.luckett at arrowgeomatics.com
Fri Jan 23 19:13:50 EST 2009
Did you figure this out with Flexible Web Layouts?  This fix works great for
Simple Web Layouts but how do we turn on Scrolling/Toolbars in the InvokeURL
for Fusion?
Is it part of the InvokeURL.js file in the /fusion/wigets/ folder?
thanks
gordon
Andrew DeMerchant wrote:
> Is there a way to modify the InvokeURL command to have it open a window
> with scrollbars and toolbars? Right now, if you tell it to open in a new
> window, that window never has scrollbars or toolbars. I need to turn
> those on somehow. I've looked through the AJAX viewer php files, but
> can't find the spot that I'd change.
> Andrew
> 	*Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/invokeurl-tp1816596p2206859.html
