[mapguide-users] invokeurl
GordonL
gordon.luckett at arrowgeomatics.com
Thu Jan 29 16:08:18 EST 2009
Done!
http://trac.osgeo.org/mapguide/ticket/832
regards
gordon
Andy Morsell wrote:
> Gordon,
> Please be sure to submit this as a bug to the Fusion project Trac.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> www.SpatialGIS.com
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of GordonL
> Sent: Thursday, January 29, 2009 12:26 PM
> To: mapguide-users at lists.osgeo.org
> Subject: Re: [mapguide-users] invokeurl
> Hi Andrew,
> ok I figured it out. It is the InvokeURL.js file.
> This file is found in the following folder:
> \www\fusion\widgets
> Here is the issue:
> At line 40 it shows:
> Fusion.Widget.InvokeURL.prototype = {
> sFeatures :
> 'menubar=no,location=no,resizable=yes,status=no,scrollbars=yes',
> Which is fine. I changed resizable=yes and added scrollbars=yes...so far
> so
> good...
> But, at line 120, it reads:
> window.open(url, this.sTarget, this.sWinFeatures);
> Ok, so the issue is that there is NO sWinFeatures...
> I changed it to read:
> window.open(url, this.sTarget, this.sFeatures);
> And voilà! I am in business...whew. I thought I was losing my touch.
> gordon
> Andrew DeMerchant wrote:
>> It wasn't part of the widget - i've been away from Fusion for too long
>> now, and really can't recall. I would imagine it was in the .js file for
>> that widget...sorry I'm no more help than that!
>> On 1/29/2009 11:44 AM, GordonL wrote:
>>> Hi Andrew,
>>> I am having trouble finding the entry in Nabble. Do you have an
>>> example?
>>> I
>>> am sure I did this a couple of years ago, but I can't find it. Can it
>>> be
>>> part of the Widget XML in Studio too?
>>> thanks
>>> gordon
>>>> I did...I also turned on the scrollbars - but I can't recall how at the
>>>> moment....do a search on Nabble, and you should find the answer.
>>>> Andrew
>>>> GordonL wrote:
>>>>> Did you figure this out with Flexible Web Layouts? This fix works
>>>>> great
>>>>> for
>>>>> Simple Web Layouts but how do we turn on Scrolling/Toolbars in the
>>>>> InvokeURL
>>>>> for Fusion?
>>>>> Is it part of the InvokeURL.js file in the /fusion/wigets/ folder?
>>>>> thanks
>>>>> gordon
>>>>>> Is there a way to modify the InvokeURL command to have it open a
>>>>>> window
>>>>>> with scrollbars and toolbars? Right now, if you tell it to open in a
>>>>>> new
>>>>>> window, that window never has scrollbars or toolbars. I need to turn
>>>>>> those on somehow. I've looked through the AJAX viewer php files, but
>>>>>> can't find the spot that I'd change.
>>>>>> Andrew
>>>>>> *Andrew DeMerchant*
>>>>>> *Computer Technologist*
>>>>>> ph.1-877-2GEMTEC x.163
>>>>>> fax 506-453-9470
>>>>>> /GEMTEC Limited<http://www.gemtec.ca>
>>>>>> /191 Doak Road
>>>>>> Fredericton, NB, Canada
>>>>>> E3C 2E6
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> *Andrew DeMerchant*
>> fax 506-453-9470
>> /GEMTEC Limited <http://www.gemtec.ca>
>> /191 Doak Road
>> E3C 2E6
> http://n2.nabble.com/invokeurl-tp1816596p2241087.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
View this message in context: http://n2.nabble.com/invokeurl-tp1816596p2241282.html
