[mapguide-users] invokeurl
Paul Spencer pagameba at gmail.com
Fri Jan 30 07:13:05 EST 2009
Thanks Gordon
Paul
On 29-Jan-09, at 4:08 PM, GordonL wrote:
> Done!
> http://trac.osgeo.org/mapguide/ticket/832
> regards
> gordon
> Andy Morsell wrote:
>> Gordon,
>> Please be sure to submit this as a bug to the Fusion project Trac.
>> Andy Morsell, P.E.
>> Spatial Integrators, Inc.
>> www.SpatialGIS.com
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of GordonL
>> Sent: Thursday, January 29, 2009 12:26 PM
>> To: mapguide-users at lists.osgeo.org
>> Subject: Re: [mapguide-users] invokeurl
>> Hi Andrew,
>> ok I figured it out.  It is the InvokeURL.js file.
>> This file is found in the following folder:
>> \www\fusion\widgets
>> Here is the issue:
>> At line 40 it shows:
>> Fusion.Widget.InvokeURL.prototype = {
>>    sFeatures :
>> 'menubar=no,location=no,resizable=yes,status=no,scrollbars=yes',
>> Which is fine.  I changed resizable=yes and added
>> scrollbars=yes...so far
>> so
>> good...
>> But, at line 120, it reads:
>>                window.open(url, this.sTarget, this.sWinFeatures);
>> Ok, so the issue is that there is NO sWinFeatures...
>> I changed it to read:
>>                window.open(url, this.sTarget, this.sFeatures);
>> And voilà!  I am in business...whew. I thought I was losing my touch.
>> gordon
>> Andrew DeMerchant wrote:
>>> It wasn't part of the widget - i've been away from Fusion for too
>>> long
>>> now, and really can't recall. I would imagine it was in the .js
>>> file for
>>> that widget...sorry I'm no more help than that!
>>> On 1/29/2009 11:44 AM, GordonL wrote:
>>>> Hi Andrew,
>>>> I am having trouble finding the entry in Nabble.  Do you have an
>>>> example?
>>>> I
>>>> am sure I did this a couple of years ago, but I can't find it.
>>>> Can it
>>>> be
>>>> part of the Widget XML in Studio too?
>>>> thanks
>>>> gordon
>>>>> I did...I also turned on the scrollbars - but I can't recall how
>>>>> at the
>>>>> moment....do a search on Nabble, and you should find the answer.
>>>>> Andrew
>>>>> GordonL wrote:
>>>>>> Did you figure this out with Flexible Web Layouts?  This fix
>>>>>> works
>>>>>> great
>>>>>> for
>>>>>> Simple Web Layouts but how do we turn on Scrolling/Toolbars in
>>>>>> the
>>>>>> InvokeURL
>>>>>> for Fusion?
>>>>>> Is it part of the InvokeURL.js file in the /fusion/wigets/
>>>>>> folder?
>>>>>> thanks
>>>>>> gordon
>>>>>>> Is there a way to modify the InvokeURL command to have it open a
>>>>>>> window
>>>>>>> with scrollbars and toolbars? Right now, if you tell it to
>>>>>>> open in a
>>>>>>> new
>>>>>>> window, that window never has scrollbars or toolbars. I need
>>>>>>> to turn
>>>>>>> those on somehow. I've looked through the AJAX viewer php
>>>>>>> files, but
>>>>>>> can't find the spot that I'd change.
>>>>>>> Andrew
>>>>>>> 	*Andrew DeMerchant*
>>>>>>> *Computer Technologist*
>>>>>>> ph.1-877-2GEMTEC x.163
>>>>>>> fax 506-453-9470
>>>>>>> /GEMTEC Limited<http://www.gemtec.ca>
>>>>>>> /191 Doak Road
>>>>>>> Fredericton, NB, Canada
>>>>>>> E3C 2E6
>>>>>>> _______________________________________________
>>>>>>> mapguide-users mailing list
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> 	*Andrew DeMerchant*
>>> fax 506-453-9470
>>> /GEMTEC Limited <http://www.gemtec.ca>
>>> /191 Doak Road
>>> E3C 2E6
>> View this message in context:
>> http://n2.nabble.com/invokeurl-tp1816596p2241087.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
> View this message in context: http://n2.nabble.com/invokeurl-tp1816596p2241282.html
