[mapguide-users] Maintaining MapGuide Session during Restart
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Fri Jan 30 03:38:01 EST 2009
Perhaps you can create a package from a Session repo?
You will run into two problems if you try to copy from Session to Library,
1) Session repo is not enumerable (a security feature, IMO useless)
2) Runtime Maps cannot be saved into Library.
Both problems can be solved by doing a custom build of MapGuide, and
removing the checks.
I seem to recal that the Session repo can be enumerated by the
Administrator.
You can't make a 100% xml copy, because the xml has attached resourcesm
which are binary files.
Regards, Kenneth Skovhede, GEOGRAF A/S
bruce_weston skrev:
> Bruce D,
> Are you suggesting that this can be done? Does anyone have a script or a
> method of copying the session repository into a library object? Is there
> even a way of creating a copy of the session as XML?
> thanks,
> Bruce W
> Bruce Dechant wrote:
>> Bruce,
>> What you are doing by trying to replace the session repository of a
>> running server is problematic and could lead to server instability. You
>> really shouldn't do this.
>> The session repository is meant for temporary runtime data only and not
>> for persistent data. If you want any of your session repository data to
>> survive a restart you need to use the library repository instead.
>> Thanks,
>> Bruce
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of bruce_weston
>> Sent: Wednesday, January 28, 2009 2:34 AM
>> To: mapguide-users at lists.osgeo.org
>> Subject: [mapguide-users] Maintaining MapGuide Session during Restart
>> I'm just wondering if anyone has managed to do this yet? This is my
>> attempted
>> MapGuide restart script to keep the contents of the session folder backed
>> up, but it doesn't work:
>> echo MapGuide Scheduler Task Starting
>> taskkill /F /FI "SERVICES eq MapGuideServer2.0"
>> net stop MapGuideServer2.0
>> REM xcopy c:\Progra~1\MapGuideOpenSource2.0\Server\Repositories\Session\*
>> c:\Progra~1\MapGuideOpenSource2.0\SessionBackup\ /E /Y
>> net start MapGuideServer2.0
>> REM xcopy c:\Progra~1\MapGuideOpenSource2.0\SessionBackup\*
>> c:\Progra~1\MapGuideOpenSource2.0\Server\Repositories\Session\ /E /Y
>> echo MapGuide Scheduler Task Completed
>> pause
>> Is there session data stored anywhere else? I really want to make the
>> process seamless for my users.
>> Bruce
>> View this message in context:
>> http://n2.nabble.com/Maintaining-MapGuide-Session-during-Restart-tp2231199p2231199.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090130/8114f3ec/attachment.html
