[mapguide-users] Maintaining MapGuide Session during Restart
bruce_weston
ross.vernal at 1spatial.com
Fri Jan 30 07:12:32 EST 2009
Hmmm. Creating a package from a session may well the be the way forward. I
will look at doing this programatically and report back to the board on my
progress!
thanks for all your help so far people!
Ross
Kenneth Skovhede, GEOGRAF A/S wrote:
> Perhaps you can create a package from a Session repo?
> You will run into two problems if you try to copy from Session to Library,
> 1) Session repo is not enumerable (a security feature, IMO useless)
> 2) Runtime Maps cannot be saved into Library.
> Both problems can be solved by doing a custom build of MapGuide, and
> removing the checks.
> I seem to recal that the Session repo can be enumerated by the
> Administrator.
> You can't make a 100% xml copy, because the xml has attached resourcesm
> which are binary files.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> bruce_weston skrev:
>> Bruce D,
>> Are you suggesting that this can be done? Does anyone have a script or a
>> method of copying the session repository into a library object? Is there
>> even a way of creating a copy of the session as XML?
>> thanks,
>> Bruce W
>> Bruce Dechant wrote:
>>> Bruce,
>>> What you are doing by trying to replace the session repository of a
>>> running server is problematic and could lead to server instability. You
>>> really shouldn't do this.
>>> The session repository is meant for temporary runtime data only and not
>>> for persistent data. If you want any of your session repository data to
>>> survive a restart you need to use the library repository instead.
>>> Thanks,
>>> Bruce
>>> -----Original Message-----
>>> From: mapguide-users-bounces at lists.osgeo.org
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of
>>> bruce_weston
>>> Sent: Wednesday, January 28, 2009 2:34 AM
>>> To: mapguide-users at lists.osgeo.org
>>> Subject: [mapguide-users] Maintaining MapGuide Session during Restart
>>> I'm just wondering if anyone has managed to do this yet? This is my
>>> attempted
>>> MapGuide restart script to keep the contents of the session folder
>>> backed
>>> up, but it doesn't work:
>>> echo MapGuide Scheduler Task Starting
>>> taskkill /F /FI "SERVICES eq MapGuideServer2.0"
>>> net stop MapGuideServer2.0
>>> REM xcopy
>>> c:\Progra~1\MapGuideOpenSource2.0\Server\Repositories\Session\*
>>> c:\Progra~1\MapGuideOpenSource2.0\SessionBackup\ /E /Y
>>> net start MapGuideServer2.0
>>> REM xcopy c:\Progra~1\MapGuideOpenSource2.0\SessionBackup\*
>>> c:\Progra~1\MapGuideOpenSource2.0\Server\Repositories\Session\ /E /Y
>>> echo MapGuide Scheduler Task Completed
>>> pause
>>> Is there session data stored anywhere else? I really want to make the
>>> process seamless for my users.
>>> Bruce
>>> View this message in context:
>>> http://n2.nabble.com/Maintaining-MapGuide-Session-during-Restart-tp2231199p2231199.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Maintaining-MapGuide-Session-during-Restart-tp2231199p2244520.html
