[mapguide-users] Two maps in the same layout
Paul Spencer
pagameba at gmail.com
Fri Jan 30 07:10:52 EST 2009
This is trickier than it should be :( Ideally it should pass an
argument which is the map that triggered the event or set the context
(this) to be the map, but neither happens.
Fortunately there are many ways around this ...
Map.registerForEvent(Fusion.Event.MAP_LOADED, mapLoaded.bind(null,
'Map'));
Map1.registerForEvent(Fusion.Event.MAP_LOADED, mapLoaded.bind(null,
'Map1'));
... which is essentially equivalent to ..
Map.registerForEvent(Fusion.Event.MAP_LOADED, function()
{ mapLoaded('Map'); });
Map1.registerForEvent(Fusion.Event.MAP_LOADED, function()
where mapLoaded now takes a parameter
function mapLoaded(s) {
switch(s) {
case 'Map':
//Map was loaded
break;
case 'Map1':
//Map1 was loaded
break;
You can also do something really simple:
Map.registerForEvent(Fusion.Event.MAP_LOADED, mapLoaded);
Map1.registerForEvent(Fusion.Event.MAP_LOADED, map1Loaded);
function mapLoaded() {}
function map1Loaded() {}
Cheers
Paul
On 29-Jan-09, at 10:06 AM, Rodolfo Moreno wrote:
> Thanks Jackie and Paul for the quickly answer.
> I was testing the two ways.
> Paul with respect to the FUSION viewer, I could place two maps in
> the same
> layout, however I could not handle suitably the event MAP_LOADED.
> this is my
> code:
> var Map;
> var Map1;
> var fusionInitialized = function() {
> $('AppContainer').resize({forceResize: true});
> Map = Fusion.getWidgetById('Map');
> Map1 = Fusion.getWidgetById('Map1');
> Map1.registerForEvent(Fusion.Event.MAP_LOADED, mapLoaded);
> // Inside of this function I would like to detect which of the
> maps(Map or
> Map1) has called
> // to this function.
> I would like that mapLoaded function to detect which of the maps(Map
> or
> Map1) called it.
> The other alternative (whether the other is not possible) would be I
> can
> send parameters to the mapLoaded function, like this:
> Map.registerForEvent(Fusion.Event.MAP_LOADED, mapLoaded,
> parameter1);
> function mapLoaded(parameter1)
> Thanks in advance,
> Paul Spencer wrote:
>> yes you can do it using the fusion viewer but you need to edit the
>> ApplicationDefinition.xml file manually (you can't do it using
>> Studio).
>> You need to have a MapGroup for each map you want to display and a
>> WidgetSet for each map you want to display. Then you need two divs
>> in
>> your page, one for each WidgetSet (referenced by the MapWidget in the
>> WidgetSet). Widgets within each widget set will only work on the
>> associated map.
>> Cheers
>> Paul
>> On 22-Jan-09, at 3:21 PM, Rodolfo Moreno wrote:
>>> Ivan good sugestion about the iframes, it's better than frameset.
>>> However I
>>> would like to do it using FUSION viewer. Is it possible?
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Rodolfo Moreno
> CivilEng
> View this message in context: http://n2.nabble.com/Two-maps-in-the-same-layout-tp2189508p2239370.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
