[mapguide-users] Two maps in the same layout
Rodolfo Moreno rmoreno at voxiva.com
Thu Jan 29 10:06:06 EST 2009
Thanks Jackie and Paul for the quickly answer.
I was testing the two ways.
Paul with respect to the FUSION viewer, I could place two maps in the same
layout, however I could not handle suitably the event MAP_LOADED. this is my
code:
var Map;
var Map1;
var fusionInitialized = function() {
    $('AppContainer').resize({forceResize: true});
    Map = Fusion.getWidgetById('Map');
    Map1 = Fusion.getWidgetById('Map1');
    Map.registerForEvent(Fusion.Event.MAP_LOADED, mapLoaded);
    Map1.registerForEvent(Fusion.Event.MAP_LOADED, mapLoaded);
function mapLoaded()
  // Inside of this function I would like to detect which of the maps(Map or
Map1) has called
 // to this function.
I would like that mapLoaded function to detect which of the maps(Map or
Map1) called it.
The other alternative (whether the other is not possible) would be I can
send parameters to the mapLoaded function, like this:
    Map.registerForEvent(Fusion.Event.MAP_LOADED, mapLoaded, parameter1);
function mapLoaded(parameter1)
Thanks in advance,
Paul Spencer wrote:
> yes you can do it using the fusion viewer but you need to edit the
> ApplicationDefinition.xml file manually (you can't do it using Studio).
> You need to have a MapGroup for each map you want to display and a
> WidgetSet for each map you want to display.  Then you need two divs in
> your page, one for each WidgetSet (referenced by the MapWidget in the
> WidgetSet).  Widgets within each widget set will only work on the
> associated map.
> Cheers
> Paul
> On 22-Jan-09, at 3:21 PM, Rodolfo Moreno wrote:
>> Ivan good sugestion about the iframes, it's better than frameset.
>> However I
>> would like to do it using FUSION viewer. Is it possible?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/Two-maps-in-the-same-layout-tp2189508p2239370.html
