[mapguide-users] Two maps in the same layout
Paul Spencer pagameba at gmail.com
Fri Jan 23 07:37:25 EST 2009
yes you can do it using the fusion viewer but you need to edit the
ApplicationDefinition.xml file manually (you can't do it using Studio).
You need to have a MapGroup for each map you want to display and a
WidgetSet for each map you want to display.  Then you need two divs in
your page, one for each WidgetSet (referenced by the MapWidget in the
WidgetSet).  Widgets within each widget set will only work on the
associated map.
Cheers
Paul
On 22-Jan-09, at 3:21 PM, Rodolfo Moreno wrote:
> Ivan good sugestion about the iframes, it's better than frameset.
> However I
> would like to do it using FUSION viewer. Is it possible?
