[mapguide-users] Generalize the data by percentage. How does
it work?
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Mon Jul 6 03:29:21 EDT 2009
You should ask where you purchased Studio if you
want information specific to Studio.
There exists a Studio forum somewhere on the Autodesk website.
Commonly, you can only generalize point or polygon data,
where an algorithm will remove points that are "close" or
"on the same line", thus producing a lighter geometry.
Regards, Kenneth Skovhede, GEOGRAF A/S
Jonathan W skrev:
> Yes Mapguide Studio version has the option. I do not believe Maestro does.
> My question thou is what it technically does. You have the option when you
> add point data to generalize that as well. How can you generalize point
> data any further?
> Jonathan
> Warren Medernach-2 wrote:
>> Hi Jonathan,
>> If you have MapGuide Studio, in the Load Procedure dialog, there is an
>> option to generalize data.
>> I'm not sure if Maestro has this option or not, you might want to check?
>> Warren M
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jonathan W
>> Sent: Tuesday, June 30, 2009 8:42 AM
>> To: mapguide-users at lists.osgeo.org
>> Subject: [mapguide-users] Generalize the data by percentage. How does it
>> work?
>> I have several very large polyline shapefiles that I wish to put into my
>> Mapguide site. I would like a faster preformance for my site by
>> generalizing these files (reducing file sizes). Could someone please
>> direct
>> me to the help file or tell me what the "Generalize the data by this
>> percentage" in the load procedure actually does. Does it remove
>> vertices?
>> Would 20% remove 4 out of 5 points along the line?
>> Thank you
>> Jonathan
>> View this message in context:
>> http://n2.nabble.com/Generalize-the-data-by-percentage.--How-does-it-wor
>> k--tp3182874p3182874.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090706/8455c7d2/attachment.html
