[mapguide-users] Bad Gateway
SandraH sahoerne at web.de
Thu Jul 2 03:30:31 EDT 2009
Hallo,
I can't get the proxy server settings, because they are set in an electronic
data processing center. However, I have done another test and found out that
if I use the url with http instead of https the error does not occur. That
means that our SSL settings are incorrect, or that a setting on the proxy
prevents the page to load correct?
Thank you in advance,
Sandra
View this message in context: http://n2.nabble.com/Bad-Gateway-tp3017109p3193874.html
