[mapguide-users] Bad Gateway
SandraH
sahoerne at web.de
Tue Jul 7 04:05:57 EDT 2009
Hallo,
We found out, that the application works neither with ISA nor with SQIUD.
The tunnel is apparently aborted by the application. The DWF viewer in
between calls to the following:
POST http://blubb:443/mapguide/mapagent/mapagent.fcgi.
This seemingly terminates the SSL tunnel and causes the MapGuide server to
an error.
Are the viewers not SSL compatible?
Sandra
View this message in context: http://n2.nabble.com/Bad-Gateway-tp3017109p3217924.html
