[mapguide-users] Generalize the data by percentage. How does it work?
Jackie Ng jumpinjackie at gmail.com
Mon Jul 6 03:33:07 EDT 2009
You are pretty much correct, the load procedure will reduce the vertex count
by the specified percentage. How it does the generalization I have no idea.
Though I believe that number is the percentage you want to reduce, not the
total percentage you are after. So if you had 5 points along the line, 20%
generalization would remove 1 point on that line.
- Jackie
Jonathan W wrote:
> I have several very large polyline shapefiles that I wish to put into my
> Mapguide site.  I would like a faster preformance for my site by
> generalizing these files (reducing file sizes).  Could someone please
> direct me to the help file or tell me what the "Generalize the data by
> this percentage" in the load procedure actually does.  Does it remove
> vertices? Would 20% remove 4 out of 5 points along the line?
> Thank you
> Jonathan
View this message in context: http://n2.nabble.com/Generalize-the-data-by-percentage.--How-does-it-work--tp3182874p3211490.html
