[mapguide-users] creating package problem
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Mon Jul 6 04:01:39 EDT 2009
Does the map have extent set?
I think you mean something else than "package".
A package in MapGuide is a copy of a folder, compressed as a zip file,
and stored outside MapGuide as a regular file.
Creating a package does not affect how MapGuide operates.
When you write "after creating package", what do you mean?
Regards, Kenneth Skovhede, GEOGRAF A/S
padmini godavarthi skrev:
> Hi kenneth,
> after creating package i just pressed "Show In Browser" button in layout
> template
> i got the map like
> http://n2.nabble.com/file/n3173735/template.jpeg
> i got an error msg in the log file................................
> Regards,
> Padmini.
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> You should get an error message when you
>> start the viewer also.
>>> Hi,
>>> when i clicked on this map i got the error msg that
>>> "<2009-06-29T15:36:01> Administrator
>>> Error: Invalid argument(s):
>>> The value cannot be less than or equal to zero.
>>> StackTrace:
>>> - MgRenderingServiceHandler.ProcessOperation line 83 file
>>> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\rendering\RenderingServiceHandler.cpp
>>> - MgOpQueryFeatures.Execute line 125 file
>>> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\rendering\OpQueryFeatures.cpp
>>> - MgServerRenderingService.QueryFeatures line 652 file
>>> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\rendering\ServerRenderingService.cpp
>>> - MgServerRenderingService.RenderForSelection line 1041 file
>>> The value cannot be less than or equal to zero."
>>> Regards,
>>> Padmini G.
>>>> What are the messages in the error log file?
>>>>> Hi,
>>>>> iam using mapguide opensource 2.0 (with .net 2.0 +IIS 5.1).
>>>>> and iam using mapguide maestro for creating packages.
>>>>> it works fine (loading package on ajax viewer).
>>>>> suddenly i got a problem from the last 2 days.the map is not showing on
>>>>> the
>>>>> browser.......
>>>>> http://n2.nabble.com/file/n3173532/template.jpeg
>>>>> i didn't get the problem.................
>>>>> why it happens???????????///
>>>>> can anybody helps me in this situation...........?
>>>>> Regards,
>>>>> Padmini G.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090706/53f25ff3/attachment.html
