[mapguide-users] Modify layout with anonymous user
euskalmap
ziburudebian at free.fr
Mon Jul 6 04:50:17 EDT 2009
thanks for your information but how do you make toYou have to create a
temporary WebLayout AND a temporary MapDefinition and then make the
temporary WebLayout point to the temporary MapDefinition.
Have you an example of code?
Thnaks
Kenneth Skovhede, GEOGRAF A/S wrote:
> If you save to "Library://" the data will be modified permanently.
> Normally the "Anonymous" user is not allowed to save to "Library://".
> If you save to "Session:<sessionid>//" the changes will only be visible to
> the current user. You must take care not to mix sessionid's.
> I think you are trying to use the WebLayout from Library, that will not
> work.
> You have to create a temporary WebLayout AND a temporary MapDefinition.
> Then make the temporary WebLayout point to the temporary MapDefinition.
> (I think your code does this)
> Then save both WebLayout and MapDefinition in "Session:<sessionid>//".
> When you redirect, you should point to the temporary WebLayout.
> As you pass in the sessionId, the viewer should be able to read it
> correctly.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> euskalmap skrev:
>> Hi,
>> I refresh my post! If you have an idea !!!
>> Sorry, I wanted to say that my c# code change the mapdefinitin in the
>> layout
>> for the current session;
>> if i use administrator user, it seems to me that my repositories is
>> modified
>> in maestro, no and i will not ?
>> For (Sample 1) my code is http://patxi.mayol.free.fr/ag_default3.aspx
>> here
>> For (Sample 2) my xml file is http://patxi.mayol.free.fr/test_after.xml
>> here
>> Thanks
>>> You mention "layout resource", but the message states a MapDefinition is
>>> saved?
>>> Anonymous can only save to the same session, only Administrator can save
>>> across
>>> sessions.
>>> As for the parse error, your document is likely invalid.
>>> For (Sample 1), can you post the related code?
>>> For (Sample 2), can you post a binary copy of the document you are
>>> trying to save?
>>> euskalmap skrev:
>>>> Hi,
>>>> I modify, by c# script, the name of the layout resource; i use the
>>>> MgUserInformation function with Anonymous user without password.
>>>> sample1 : In mapguide administrator this user have no role => so when i
>>>> load
>>>> the page i have this message :
>>>> Permission denied to resource:
>>>> Session:98d50e40-ffff-ffff-8000-0016d44491c1_en_7F0000010AFC0AFB0AFA//Map_40312.MapDefinition
>>>> sample 2 : if i add the role Adminstrator and Map Author of the
>>>> Anonymous
>>>> user, i have this message :
>>>> An exception occurred in DB XML component. Error: XML Indexer: Fatal
>>>> Parse
>>>> error in document at line, 1, char 1. Parser message: Invalid document
>>>> structure
>>>> I understand anything ! Have you an idea ?
>>>> Thanks
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Modify-layout-with-anonymous-user-tp3092823p3212013.html
