[mapguide-users] SQL Server Data not appearing in Fusion
Paul Spencer
pagameba at gmail.com
Tue Jul 7 13:53:55 EDT 2009
can you check your apache error log. I expect it is a bug in Fusion's
php code.
Cheers
Paul
On 7-Jul-09, at 1:51 PM, kevin_t wrote:
> Hi all,
> I have a problem where my map in a fusion/flexible layout doesn't
> load in my
> browser if I have data from SQL Server 2008. It loads fine in the
> basic
> layout, so it is unlikely that it's a SQL Server issue. I am using
> MapGuide
> Enterprise 2010 with SQL Server 2008 Trial version. The browser I
> tested
> are Firefox and IE.
> My steps are as follows:
> - Import shapefile to SQL Server 2008 using SQL Server 2008 Spatial
> Tools.
> - Create a data connection in MG Studio 2010 to it with the OSGeo FDO
> Provider for SQL Server Spatial.
> - Create the layer and add it to a map that is referenced by a fusion
> layout.
> - View the layout in a browser.
> Does anyone know if this is a bug with fusion layouts and if there
> is a
> workaround?
> View this message in context: http://n2.nabble.com/SQL-Server-Data-not-appearing-in-Fusion-tp3220760p3220760.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
