[mapguide-users] SQL Server Data not appearing in Fusion
kevin_t tai_kevin at hotmail.com
Tue Jul 7 13:51:40 EDT 2009
Hi all,
I have a problem where my map in a fusion/flexible layout doesn't load in my
browser if I have data from SQL Server 2008.  It loads fine in the basic
layout, so it is unlikely that it's a SQL Server issue.  I am using MapGuide
Enterprise 2010 with SQL Server 2008 Trial version.  The browser I tested
are Firefox and IE.
My steps are as follows:
- Import shapefile to SQL Server 2008 using SQL Server 2008 Spatial Tools.
- Create a data connection in MG Studio 2010 to it with the OSGeo FDO
Provider for SQL Server Spatial.
- Create the layer and add it to a map that is referenced by a fusion
layout.
- View the layout in a browser.
Does anyone know if this is a bug with fusion layouts and if there is a
workaround?
View this message in context: http://n2.nabble.com/SQL-Server-Data-not-appearing-in-Fusion-tp3220760p3220760.html
