[mapguide-users] Can Cartographic Stylization Use Symbol libraries?
Scott Hameister scotth at mpowerinnovations.com
Mon Jul 13 17:07:37 EDT 2009
That's a straight point symbol not using the cartographic stylization
engine, which will allow me to use HWY shields as labels....
The HwyShield  Example gets me closer, but that doesn't use a
symboldefinition or a symbol library or even hex info...It confuses me more
since it points at InterstateShield.png...God knows where that is stored
since its not local????
<ResizeControl>'AdjustToResizeBox'</ResizeControl>
      <Reference>
        <ResourceId></ResourceId>
        <LibraryItemName>'InterstateShield.png'</LibraryItemName>
      </Reference>
I downloaded every State Hwy Symbol and created a symbol library out of
it...And I want to be able to use those as numbered labels..Was hoping to
create a master Set and contribute them back to the Group...
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Tom Lazo /
Stygy
Sent: Monday, July 13, 2009 3:39 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Can Cartographic Stylization Use Symbol
libraries?
Have you seen the phpviewerexample??,
http://mapguide.osgeo.org/download/releases/2.0.x-samples.
Well..download it and open :
phpviewersample\findaddress\templates\addressmarker.xml.
I dunno if it helps...but this example uses a Symbol Library:
<PointSymbolization2D>
            <W2D>
              <Unit>Millimeters</Unit>
              <SizeContext>DeviceUnits</SizeContext>
              <SizeX>15</SizeX>
              <SizeY>15</SizeY>
              <W2DSymbol>
<ResourceId>Library://Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary</
ResourceId>
                <LibraryItemName>PushPin - Blue</LibraryItemName>
              </W2DSymbol>
            </W2D>
</PointSymbolization2D>
Srry if it does not help.
Tom
> In every example I find they point at a symboldefinition and not a
> library..
> i.e.
> <Image>
>       <Reference>
>         <ResourceId>'Library://HWYSYM.SymbolDefinition'</ResourceId>
>         <LibraryItemName>'CA_STH'</LibraryItemName>
>       </Reference>
>       <SizeX>10.8</SizeX>
>       <SizeY>11.2</SizeY>
>       <PositionX>0</PositionX>
>       <PositionY>0.8</PositionY>
>     </Image>
> mapguide-users mailing list
http://n2.nabble.com/file/u222842/warning.png   Stygy is not a living being!
View this message in context:
http://n2.nabble.com/Feature-Vertices-%28Solution%29-tp3232857p3252872.html
