[mapguide-users] Problem in displaying map
Dave Wilson dave.wilson at autodesk.com
Tue Jul 14 10:46:12 EDT 2009
You are missing a .prj file which contains the coordinate system information. You will need to set a coordinate system on the feature source (Data connection) so that when you create a map it knows what coordinate system the data is in. If you don't know you could use arbitrary xy meters for example, but you won't be able to mix this with other data of known coordinate systems using only xy.
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Stefan Dalakov
Sent: Tuesday, July 14, 2009 5:56 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Problem in displaying map
Annoying typo.
I meant
*** 3 or more files  instead of 2 ***
Stefan Dalakov
Stefan Dalakov wrote:
> Sreejith,
> Do you see any preview of layer and map ?
> And in general, you should have 3 or more files  instead of 3 for this
> district data - district.dbf, district.shp, district.shx.
> Stefan Dalakov
> sreejith R wrote:
>> Hello,
>> I insatlled all softwares. I have two file district.shp and
>> district.dbf. To display the map using this files, I completed the
>> five steps that are dataconnection,layer,map,fusion application and
>> layout.but I didn't get the display of map.Please tell me what are
>> the problems ?
>> Sreejith.R
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
