[mapguide-users] Add layers to the map
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Jul 16 04:01:38 EDT 2009
You should also save the LayerDefinition.
Beware that saving the LayerDefinition will change the layer for all
current and future users.
Instead you need to save a copy, and make the layer.ResourceId in line
43 point to this temp one instead.
Regards, Kenneth Skovhede, GEOGRAF A/S
euskalmap skrev:
> Hi,
> thanks, it's running.
> so, the last question : i have adding 3 lines in my code to update the
> filter of the layer (see  http://patxi.mayol.free.fr/public/test2.pdf my
> sample , line 47).
> This new modify do not run : How can i associate the new filter with the
> layer ?
> euskalmap.
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> You should also set
>> "layer.Visible = true;"
>> when adding the layers.
>> euskalmap skrev:
>>> Hi,
>>> In Masetro, I have 1 layout with a reference to a map (Library://Ag
>>> Base/Carte/MyMap.MapDefinition); the map MyMap contents no layers because
>>> i
>>> want to load the layers dynamicly.
>>> Another map MyMap_NEW contents 5 layers.
>>> So, my code modify the resource in layout (mapdefinition become
>>> Library://Ag
>>> Base/Carte/MyMap_NEW.MapDefinition) and add the layers from MyMap_NEW.
>>> Here is my  http://patxi.mayol.free.fr/public/test2.aspx code
>>> when i load my web page, i see temporarily the layers on the left and 2
>>> seconds later, they disappear : and no map is displaying!!
>>> Have you an idea ?
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090716/476380fc/attachment.html
