[mapguide-users] Add layers to the map
euskalmap ziburudebian at free.fr
Fri Jul 17 04:39:16 EDT 2009
ok, thanks i try this.
Be careful in the API OSGeo.MapGuide.MaestroAPI.dll,
ResourceTypes.LayerDefinition do not exist, it is
ResourceTypes.LayerDefiniton.
I think a bug in the dll definition.
euskalmap
Kenneth Skovhede, GEOGRAF A/S wrote:
> You should also save the LayerDefinition.
> Beware that saving the LayerDefinition will change the layer for all
> current and future users.
> Instead you need to save a copy, and make the layer.ResourceId in line
> 43 point to this temp one instead.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> euskalmap skrev:
>> Hi,
>> thanks, it's running.
>> so, the last question : i have adding 3 lines in my code to update the
>> filter of the layer (see  http://patxi.mayol.free.fr/public/test2.pdf my
>> sample , line 47).
>> This new modify do not run : How can i associate the new filter with the
>> layer ?
>> euskalmap.
>>> You should also set
>>> "layer.Visible = true;"
>>> when adding the layers.
>>> euskalmap skrev:
>>>> Hi,
>>>> In Masetro, I have 1 layout with a reference to a map (Library://Ag
>>>> Base/Carte/MyMap.MapDefinition); the map MyMap contents no layers
>>>> because
>>>> i
>>>> want to load the layers dynamicly.
>>>> Another map MyMap_NEW contents 5 layers.
>>>> So, my code modify the resource in layout (mapdefinition become
>>>> Library://Ag
>>>> Base/Carte/MyMap_NEW.MapDefinition) and add the layers from MyMap_NEW.
>>>> Here is my  http://patxi.mayol.free.fr/public/test2.aspx code
>>>> when i load my web page, i see temporarily the layers on the left and 2
>>>> seconds later, they disappear : and no map is displaying!!
>>>> Have you an idea ?
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Add-layers-to-the-map-tp3230740p3274250.html
