[mapguide-users] Don't Try This At Home - Corrupted DB XML Repository
Crispin_at_1Spatial crispin.hoult at 1spatial.com
Fri Jul 17 12:31:13 EDT 2009
All,
Today I destroyed my MG library repository... and I can do it again.
If you want to test this pls back-up first - it's quite easy to do -- for
example in a training session (oops!)
I was watching the server in \interactive mode...
 * Using Maestro create a new folder at server root "New Folder"
 * Drag the folder to the left - NULL exception (folder disappears into a
black hole)
 * Create another new folder at root called the same thing "New Folder"
 * Drag the folder to the left - a prompt appears to overwrite - say
"Yes"... another NULL exception
 * Try and restart your MGServer
--> "An exception occurred in the XML parser"
I have no idea how to get my repository "fixed" apart from re-importing from
a backup package.
db_recover etc do not help.
 Crispin
View this message in context: http://n2.nabble.com/Don%27t-Try-This-At-Home---Corrupted-DB-XML-Repository-tp3276438p3276438.html
