[mapguide-users] Don't Try This At Home - Corrupted DB XML Repository
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Sat Jul 18 05:52:42 EDT 2009
Could you log the NULL exception with a ticket for Maestro?
To restore your db, try to go to the webform:
http://localhost/mapguide/mapagent/index.html
Use the "DeleteResource" function, and in the ResourceId field enter:
"Library://New Folder/"
Then click Submit, the defect resource should now be removed, and
everything
should work as normal.
Regards, Kenneth Skovhede, GEOGRAF A/S
Crispin_at_1Spatial skrev:
> All,
> Today I destroyed my MG library repository... and I can do it again.
> If you want to test this pls back-up first - it's quite easy to do -- for
> example in a training session (oops!)
> I was watching the server in \interactive mode...
>  * Using Maestro create a new folder at server root "New Folder"
>  * Drag the folder to the left - NULL exception (folder disappears into a
> black hole)
>  * Create another new folder at root called the same thing "New Folder"
>  * Drag the folder to the left - a prompt appears to overwrite - say
> "Yes"... another NULL exception
>  * Try and restart your MGServer
> --> "An exception occurred in the XML parser"
> I have no idea how to get my repository "fixed" apart from re-importing from
> a backup package.
> db_recover etc do not help.
>  Crispin
