[mapguide-users] Don't Try This At Home - Corrupted DB XML Repository
Crispin_at_1Spatial crispin.hoult at 1spatial.com
Mon Jul 20 04:34:35 EDT 2009
Thanks Kenneth,
Once you have restarted the MG server (on a nightly script or other reason)
the corrupt respository means the MG service will not start so no access to
the mapagent APIs.  But good tip - thanks.
I ended up having to delete the server\repository files to get MG to
recreate them (clean) from scratch.
 Crispin
I'll file a ticket...
Kenneth Skovhede, GEOGRAF A/S wrote:
> Could you log the NULL exception with a ticket for Maestro?
> To restore your db, try to go to the webform:
> http://localhost/mapguide/mapagent/index.html
> Use the "DeleteResource" function, and in the ResourceId field enter:
> "Library://New Folder/"
> Then click Submit, the defect resource should now be removed, and
> everything
> should work as normal.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Crispin_at_1Spatial skrev:
>> All,
>> Today I destroyed my MG library repository... and I can do it again.
>> If you want to test this pls back-up first - it's quite easy to do -- for
>> example in a training session (oops!)
>> I was watching the server in \interactive mode...
>>  * Using Maestro create a new folder at server root "New Folder"
>>  * Drag the folder to the left - NULL exception (folder disappears into a
>> black hole)
>>  * Create another new folder at root called the same thing "New Folder"
>>  * Drag the folder to the left - a prompt appears to overwrite - say
>> "Yes"... another NULL exception
>>  * Try and restart your MGServer
>> --> "An exception occurred in the XML parser"
>> I have no idea how to get my repository "fixed" apart from re-importing
>> from
>> a backup package.
>> db_recover etc do not help.
>>  Crispin
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Don%27t-Try-This-At-Home---Corrupted-DB-XML-Repository-tp3276438p3287652.html
