[mapguide-users] Display malayalam in the map
Dave Wilson dave.wilson at autodesk.com
Tue Jul 21 10:37:20 EDT 2009
There is a MySQL provider as well you could use. The problem is still similar. You need to have the required font support (code page/language stuff) installed on the server.
If you don't have a .cpg file you could create it by simply Googling the codepage for your language and saving the value (just the code that's it) in a file called .cpg. I suspect this isn't the problem. It's more likely the font being used to display the characters. Try using MS Gothic or P Gothic. That works for most Asian fonts.
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of sreejith R
Sent: Monday, July 20, 2009 10:54 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Display malayalam in the map
Dear Dave,
I want to desplay Malayalam font of places that read from my MySQL database.I enter the unicode of that places in the table. I converted this table into .csv format and then convetred that into shape file.After conversion I got files with extensions .dbf,.sbx,.sbn.shp,.shx. There is no  .cpg  file.  Is there any way to connect the mysql table to the map directly to display malayalam or any other way for that? Please help me...
On Mon, Jul 20, 2009 at 8:25 PM, Dave Wilson <dave.wilson at autodesk.com<mailto:dave.wilson at autodesk.com>> wrote:
The font you need must be installed on the MapGuide server machine for this to work. There may also be a .cpg file with the .shp file which indicates the codepage. You might check this codepage/associated language files are installed on your MapGuide server machine as well. On Windows this is under Regional Settings.
Regards,
Dave
From: mapguide-users-bounces at lists.osgeo.org<mailto:mapguide-users-bounces at lists.osgeo.org> [mailto:mapguide-users-bounces at lists.osgeo.org<mailto:mapguide-users-bounces at lists.osgeo.org>] On Behalf Of sreejith R
Sent: Monday, July 20, 2009 2:47 AM
Subject: [mapguide-users] Display malayalam in the map
Hello,
I have doubt.How to display malayalam font in the map.I have shape file that contain malayalam unicode.Can I create a map using this shape file that displays malayalam in the map. Anybody know this,please help me.
Sreejith.R
mapguide-users mailing list
mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapguide-users
Sreejith.R
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090721/ea32fbf7/attachment.html
