[mapguide-users] Selection Limit?
Tom Lazo / Stygy
tom.lazo at hotmail.com
Fri Jul 24 16:45:21 EDT 2009
Hi Nick,
Actually, there is a feature selection limit. Its name is
SelectionFilterSize and u can find it on 2 config files:
- C:\Archivos de programa\MapGuideOpenSource2.0\Server\Bin\serverconfig.ini
- C:\Archivos de
programa\MapGuideOpenSource2.0\WebServerExtensions\www\webconfig.ini
Both on [GeneralProperties].
Just change that number and restart your services.
Hope it helps.
Tom
Nickthetemp wrote:
> Hello
> I am using the following code to read through a selection and grab a 7
> digit number, which is then put into an array:
> $layerClassName = $layer->GetFeatureClassName();
> $selectionString = $selection2->GenerateFilter($layer,
> $layerClassName);
> // Get the feature resource for the selected layer
> $layerFeatureId = $layer->GetFeatureSourceId();
> $layerFeatureResource = new
> MgResourceIdentifier($layerFeatureId);
> // Apply the filter to the feature resource for the selected
> layer. This returns
> // an MgFeatureReader of all the selected features.
> $queryOptions->SetFilter($selectionString);
> $featureReader =
> $featureService->SelectFeatures($layerFeatureResource, $layerClassName,
> $queryOptions);
> // Process each item in the MgFeatureReader, displaying the
> PID
> while ($featureReader->ReadNext())
> $valArray[$counter] = $featureReader->GetInt32('PID');
> $counter = $counter + 1;
> The code works fine until I hit a larger selection number. Is there a
> limit on the number of features that can be selected from a database?
> I get the following error when the selection is big:
> An exception occurred in FDO component. RDBMS: [IBM][CLI
> Driver][DB2/LINUX] SQL0010N The string constant beginning with ""MAPI"
> does not have an ending string delimiter. SQLSTATE=42603
> Any help would be appreciated
> Nick
http://n2.nabble.com/file/u222842/warning.png Stygy is not a living being!
View this message in context: http://n2.nabble.com/Selection-Limit--tp3321984p3322559.html
