[mapguide-users] Non-Administrator Users Can't Login
Bloozitis
dsoper at uoregon.edu
Mon Jul 27 12:44:13 EDT 2009
Hi Mauricio,
Could you please be so kind as to explain, in detail, what these
permissions are? Currently, I have set up a test account and a user
account on the workstation with read and execute permissions.
Unfortunately, there is no mention in the documentation of what
permissions users need to access this.
Cheers,
Dennis
[mailto:ml-user+109705-477115064 at n2.nabble.com]
Sent: Thursday, July 23, 2009 1:08 AM
To: Dennis Soper
Subject: Re: [mapguide-users] Non-Administrator Users Can't Login
You need to set the right permissions of the repository folders.
Bloozitis wrote:
I've created a test user, assigned it to a "mapauthors" group I created,
which assigns the user to the "Authors" role. When I attempt to login
as this user, I get an "Authentication failed. Please enter a valid
username and password. The following message is in the error log:
<2009-07-13T14:58:06> Map Admin 128.223.67.19 tester
Error: Unauthorized access.
StackTrace:
- MgSiteServiceHandler.ProcessOperation line 83 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services
\site\SiteServiceHandler.cpp
- MgOpEnumerateServers.Execute line 96 file
\site\OpEnumerateServers.cpp
- MgSecurityManager.Authenticate line 213 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\common\m
anager\SecurityManager.cpp Unauthorized access.
Any ideas what I'm doing wrong? I'm running the bundled Apache on
Windows 2003 Server with a PHP development environment.
Cheers,
Dennis
View message @
http://n2.nabble.com/Non-Administrator-Users-Can%27t-Login-tp3257838p330
8151.html
To unsubscribe from Non-Administrator Users Can't Login, click here
< (link removed)
nb24uZWR1fDMyNTc4Mzh8MjEyMDkxMDg0Mg==> .
View this message in context: http://n2.nabble.com/Non-Administrator-Users-Can%27t-Login-tp3257838p3334926.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090727/cec4b3fa/attachment.html
